My IBM 4317 will not print. I can see the job spool with the printer page open, but the printer will not come out of powersave mode to print the job. I eventually get an error in the print job.
Troubleshoot/hpDeskJet 895Cse printers,how to cancel a print job
Print jobs are kept in a print spool on your computer. Turning off your printer only clears the printer. To clear the print spool on a Windows type computer, look for the printer icon on the task bar, lower right hand corner of the monitor. Double click on the small icon will open the list of pending print jobs. Select the one you wish to delete, then cancel the print job.
Feb 18, 2015 | Office Equipment & Supplies
Even since we install the edimax server, the printer will just halt and we have to reset the spooler again
Setting the location of the spool folder By default the spool folder is located at systemroot\System32\Spool\Printers. However, this drive also holds the Windows system files. Because these files are frequently accessed by the operating system, performance of both Windows and the printing functions might be slowed.
If your print server serves only one or two printers with low traffic volumes, the default location of the spool folder is sufficient. However, for high-volume printing requirements, to support large numbers of printers, or to support large print jobs, you should relocate the spool folder. For best results, move the spool folder to a drive that has its own controller, which reduces printing's impact on the rest of the operating system.
For information on relocating the print server spool folder, see Change the spool folder location.
To set up a printer to print to multiple devices
  1. Open Printers and Faxes.
  2. Right-click the printer you are using, and then click Properties.
  3. On the Ports tab, select the Enable printer pooling check box.
  4. Click each port where the printers you want to pool are connected.
Notes
  • To open Printers and Faxes, click Start, and then click Printers and Faxes.
  • With printer pooling, the printers must be the same type of printer using the same printer driver.
  • The previous procedure assumes the printers you want to pool are already in the Printers and Faxes folder.
  • Check for print jobs in que,this can cause the printer to spool if a print job is in que.
Dec 09, 2010 | Edimax PS-3103P (ps-3103p) Print Server
My printer will not print. The print job in the
Here are instructions on how to delete the print jobs stuck in the queue. Follow the instructions carefully:
First, you have to stop the Print Spooler. To do this:
1. Click on the Windows logo start button.
2. Go to Control Panel
3. Open Administrative Tools
4. Open Services
5. It will pop-up a Services window. Scroll through the list and look for Print Spooler.
6. Double-click on Print Spooler, make sure Startup type is Automatic and click on the Stop button. Click on Ok button. Set the window aside.
Second, you need to clear the print jobs in the Spool folder. To do this:
2. Type Spool in the Search bar(Vista) or click on Run(XP) and type Spool
3. Open Printers folder
4. Delete all the files in the Printers folder. Close the window.
Third, you have to enable the Print Spooler. To do this:
1. Go back to Services window.
2. Double-click on Print Spooler, and click on the Start button. Click on Ok button. Close the Services window. Click on the Windows logo start button. Go to Control Panel and open Printers folder. Refresh the page. That should clear the print queue now. Try to print again. If problem is not resolved, maybe it's a communication problem. You probably need to reinstall software. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 15, 2010 | Lexmark X7675 Wireless All-in-One Printer
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
HP2420dn printer spools SLOOOOOWLY
try to change spool settings
Control Panel-Printer Properties-Advanced Tab
Select Spool Print Documents-Start printing after last page is spooled.
Aug 11, 2009 | HP LaserJet 2420 Printer
Error 116-365 on dc 3535
That is a hard drive error.
There is a job stuck on it.
Hold 4 + stop + powersave as you turn on the machine.
That will cause the Hard drive to initialize and should clear the job.
I have seen that caused by someone doing an internet print job.
You may want to unplug the printer cable and see if an incoming job is corrupting the network. I have even seen networks be hacked and the machines affected.
If that doesn't reset it. Check the connections to the hard drive.
When you do the hard drive initialization. Hold the 4 , the stop, and power save as you power it on , hold the buttons until you see the progress bar appears on the screen, then release the keys.
Jul 06, 2009 | Xerox DocuColor 3535 Copier
I have a hp laserjet 4100n and everytime i print it keep telling me that manualy feed plain letter paper but I wanted to automatically print on tray 2 which it does not, I know my settings are wrong if it...
The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page:
MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT.
The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to check the paper back stop in tray 2.
The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray.
Or the arms on the tray that operate the switches are not moving properly.
You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps.
Mar 04, 2009 | HP LaserJet 4100n Printer
Page advance
Dec 18, 2007 old problem... If you have same problem currently, post it and will get you fixed. March 14, 2009.
Dec 18, 2007 | IBM 6400 Matrix Printer
26 people viewed this question
k24674
jasbo
jasbo
