Question about T-Mobile Dash Smartphone
My alarm will still go off after i turn it off, how can i fix it?
    Scholar:
  • 149 Answers
Completely clear your alarms w/ this 3rd part application called SKTools
Get the WM6 version for smartphone (if you have WM6).
It's a trial but it clears up to 6 entries. Use that and then get a 3rd party alarm clock like Gentimer
This is a known issue w/ Windows Mobile's native alarm clock.
Hope this helps,
Bill
Posted on Sep 09, 2009
I disconnected the battery to charge it. when trying to reconnect it, the alarm goes off. What should I do?
Daniel, On your key fob try turning alarm off, if not install battery, then start the car,shut car off and lock doors with remote this will reset alarm.
Mar 28, 2016 | Cars & Trucks
How to turn off the 3 chrip reminder to turn on my alarm if I turn off my bike
Hi, ZweefvliegerNL for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Thread SPY 5000 Alarm User manual and How Too
How do mute or silence my alarm siren chirps
Setting your alarm to chirp less mode what the trick Harley Davidson Forums
Alarm How do you silent the chirp when arming with the key fob
Paging Alarm
Jun 22, 2015 | Motorcycles
My car alarm disconected n it doesnt start
Disconnecting the alarm prevents the starter from turning and the fuel pump from running. Gotta fix the alarm system.
Oct 03, 2014 | Nissan Primera Cars & Trucks
Alarm wont turn off
Start the vehicle with the key. Also try unlocking the vehicle with the electric locks. Either should fix the problem.
Oct 29, 2012 | 2000 Chrysler Sebring
How do I fix the driver door ajar alarm on my 2002 lincoln ls ?
You need to check the door switch. You can't pull the fuse because you will stop other essential items. If you can find the sounder under the dash you can disconnect it.
it uses a sensor. This video shows you how to fix.
https://www.youtube.com/watch?v=8LsLfWzMhf8
Feb 13, 2018 | 2002 Lincoln LS
Can the beeping alarm be turned off?
usually if you turn the power off and on after a short delay the beep should go away. But the alarm fault code will keep showing on the display / drawer panel light until fault is fixed.
Hope this helps.
Feb 03, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Have a 2000 VW Beetle. The alarm won't turn off!
My 2000 Beetle does same thing (although not all the time). Just found an internet post that suggests there is a problem in the door lock sensor. I assume you are using a regular key - not
the keyless entry - like I am. He also said that you can disable the alarm (also disables the
keyless entry - which doesn't bother me) by leaving the front door AND the rear trunk open and
starting the car up. Seems to work so far. I will get the door lock sensor replaced and turn the
alarm system back on (not sure how yet), and let you know if that stops the problem.
Jul 24, 2009 | 2000 Volkswagen Beetle
Won't start after cleaning battery terminals
Sounds like you have an aftermarket alarm with starter disable. By disconnecting the battery the alarm reset and the defualt setting is usually to set the alarm automatically (active arming). You have three options..
A. If you have the key fob that went with the alarm you can disarm the alarm.
B. If no key fob is available you can disconnect the battery again, turn the ignition key to the on position and reconnect the battery. This usually doesn't allow the alarm to set and allows the car to start.
C. Remove the aftermarket alarm system. This is usually the long term fix i recommend if the fob isn't available. Option B should get you going though.
May 09, 2009 | 1993 Toyota Corolla
T-Mobile Dash Smartphone Logo
183 people viewed this question
Top T-Mobile Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
