Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Need to clean or replace fitler - Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
  • 22 Answers
If you have a foam typye fillter you can wash if its a cardboard base filter you need to repace
Posted on Sep 15, 2009
I have a 2001 GMC Jimmy 4.3, it surges at low speed but when accelerated runs fine. Any idea what the cause might be?
If EGR comes up, take it off and clean it, see if that clears it up, it may be sticking. Would also clean your throttle body, and replace fuel filter.
Mar 12, 2015 | 2001 GMC Jimmy
How do u change a fuel fitler for a 1997 dodge caravan
The fuel filter is mounted on the top of the fuel tank, the tank must be dropped out to replace the filter which is a complete fuel filter and fuel line assembly. Under normal driving condition this filter is never replaced unless the fuel pump is replaced due to failure.
Dec 12, 2012 | 1997 Dodge Caravan
2000 chevy truck poor air flow thru duct work
go under right side dash and look for an acsees panel on the evaporator case with one screw in it 5.5 mm remove your clogged clean air filter if that doesnt fix it the evaporator core is clogged with dirt and debrie.but the clean air fitler should fix your problem
Jan 21, 2011 | Chevrolet Silverado 1500 Cars & Trucks
What does the "Clean Mode" do? We had a pool party and the water
clean mode is if you have your cleaner on make sure chemicals are correct super shock and clean fitlers
May 31, 2010 | Jandy AQUALINK RS TELELINK KIT
How do i change the fuel fitler in a 03 power
should have a cover on top of the engine, lift cover , there will be a cylindrical Fuel Filter housing with a lever on the side and a cap on top. remove the cap, remove the old filter & install the new filter & the NEW seals. use the little lever to drain the old fuel & any water from the fitler housing & start engine per normal Diesel starting procedures
Oct 08, 2009 | 2003 Ford F Super Duty Chassis Cab
Smelly Animal Bagless Dyson
You've cleaned up urine...somehow. To remove that odor, go to a local flea mkt or store that sells essential oils and buy "Citronella" (smells awesome) 1/2-1oz. bottle will last forever. Add 4-5 drops to the paper filter element - smell gone!
Good Luck
Jun 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Compressor turns on but unit doesn't cool.
take the air filter out and see if there is a dramatic improvement - if so clean the air fitler - otherwise it may need regassing
Jul 09, 2008 | Haier hwr10xc6 Air Conditioner
Air fitler cleaning
REMOVE THE BOTTOM PANEL OF THE BACK OF THE TV. CLEAN OUT PANEL WITH WATER AND DRY.(IF NOT DRYED OUT PROPERLY CAN CAUSE SHORT) CLEAN OF THE FAN ON THE BACK RIGHT SIDE (REMOVE ALL DUST) THEN REINSTALL BACK PANEL. TV SHOULD WORK
Nov 07, 2007 | Panasonic PT-61LCX65 61" Rear Projection...
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
