Question about LG DU-42PX12XC 42 in. Plasma HDTV
My lg tv wont turn on.
It does not seem to recongnize that it is plugged in. The power light does not show any more. I had it on a surge protector and all other electronics on the power supply are fine. Is there a way to reset the tv or is there something wrong that is not easily fixed
    President:
  • 1,077 Answers
First, I would try leaving the TV unplugged for an hour so the TV can discharge and reset itself.
If this doesn't work, it maybe something simple like a blown fuses inside the TV that needs replacing.Radio Shack or some electronic store will carry the fuses.
If the other two ideas doesn't solve it, we're talking about a power supply board related problem. I can't actually look at your TV over the internet. But, the most common problem with flat panel TV are the power supply board for the screen itself and the main power supply board for the rest of the TV. Commonly a bad capacitor or transformer will be on the board.
If you have some electronic experience and want to repair it yourself, you can sometimes find a Service Manual for your TV over the internet. Normally, costs less than $20. It will have diagrams, schematics, and part number list for the TV.
Posted on Sep 09, 2009
After power surge panasonic hdtv projection tv model # PT-53WX42F wont come on red light flashes
Bobbie, It dose not sound like surge protector was real effective, the TV will have to come apart to diagnose what has all blown, capacitors, boards etc. Google search can help show how it is done.
Enter all your TV's info, will not power on repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 08, 2016 | Panasonic Televison & Video
Sony KDL 46HX820 turns on, then off and red light blinks four times.
Re: Bravia KDL46EX720. Red LED blinks 4 times and TV wont turn on. What is the problem?
Do a Power Reset.
1. Turn off the TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If the issue still persists after performing power reset, that may be an indication that the TV needs service. You may refer to this link to locate the nearest Sony authorized service center in your area.
Oct 21, 2014 | Sony KDL-46HX820 - 46" BRAVIA 1080p LED...
Had power surge. Tv was on surge protector. Now no power will come on and just makes a buzzing sound.
Have you tried plugging it in without the surge protector? I would wager that either a) the surge protector needs to be reset/turned on and off depending on the model or b) either your TV and/or surge protector have been damaged by the power surge.
Try plugging the TV straight into the outlet and see if that helps.
Oct 25, 2012 | Televison & Video
I turned off my seike tv model number se321fb and now it wont turn back on? the surge protector has power how do i get it to come back on?
Even though the indicator light on your surge protector is on, the surge protector outlets may not be working. Test it by plugging in a different electronic to make sure it still works.
It could also be a problem with your remote, such as dead batteries or that the remote is no longer programmed with the correct codes.
Here are a couple of troubleshooting checklists that can help you identify the problem and what you can do to solve it:
Remote not working
No picture on TV
I hope this helps!
Aug 03, 2012 | RCA Televison & Video
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
We had bad weather lights went out ..had tv plugged into a power surge plug ...now that i have power back tv wont come on
Some will say a surge protector will save electronics. I can tell you they may not help at all. A power surge is extremely fast and can over ride the surge protector. If you think you can repair this TV, I would certainly remove the back cover and inspect. Occasionally the only problem for repair is to replace the main fuse. Remember, this happens rarely. Most cases after a surge the TV will need to be inspected by a TV tech. Almost anything, in a power surge will damage the TV. There is no certain area that will not be damaged, expect it any where. Thanks for asking and show all hands of support!
Mar 30, 2011 | Philips 47PFL3704D 47 in. LCD TV
No indicator light or power
Please look at these two links; I suspect your problem is related:
http://www.fixya.com/support/t4592070-tv_no_power_will_not_switch
http://www.fixya.com/support/t4596948-tv_stopped_working_bit_fizzing
This model seems to be having a ton of power supply problems.
Apr 20, 2010 | LG 42LC2D 42 in. LCD HDTV
Does my samsung tv keeping turning itself off because of not having plugged it into a surge protector or is it more a fault with my tv
It is a fault with your power supply module actually inside the tv...take it to a local service center or if its under warranty take it back. surge protectors help prevent issues like this occuring due to damage to the power supply from surges but not having one wont cause these problems unless it has recieved a surge.....in future i would use a surge protector on all your expensive appliances, surges and power fluctuations are very common in mains power i live near the mines and we have power problems all the time!! hope this helps,ben
Aug 11, 2009 | Samsung LE40R74BDX 40 in. LCD Television
Cannot get power to our canon mp830
plug in a light into surge protector and see if it works if not surge protector is bad or battery is shot if it has one!!i have numerous surge protectors that went bad try plugging printer into wall outlet and if working its surge protector!!!
Jun 22, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Tv won't turn on
I suggest you unplug the set for about 15 minutes and then plug it in and try again. Sounds like you may have had a power surge/bump in the middle of the night. Althoguh you are using a surge protector, doesn'r mean the devise hooked to it can't lock up during a power surge.( Surge Protectors are an insurance policy only, not a garrentee ). If unplugging the set and waiting doesn't fix it, it will need to have the power supply section of the board repaired. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Protron PLTV-32 Television
LG DU-42PX12XC 42 in. Plasma HDTV Logo
1,814 people viewed this question
Computer Repairing
Computer Repairing
