Question about Graco Alano Travel System 7F08DSW3 Stroller
Back seat wont stay up
I did fix everything but 2 miss and i forget how to put it back on the back of seat wont stay up and i have 2 string out but forget to where put it on
We had the same problem and my husband just figured it out. Push the seat all the way forward. You'll see a whole in the plastic on each side. push the string through the whole and wrap around bottom cutout for the strap.
Posted on Sep 23, 2009
I need help putting my front seats back in. my dad had took them out and he has passed away and me and my brother are trying to put it back together. the holes for the seat wont line up?? am I missing
Pull the handle as if the seat were installed and you were going to move it forward or back. They will slid back and forth on the seat so you can align the holes. set both sides even once you get the correct line up. After you put in front or rear 2 bolts then slide seat to install the other 2. Hope this helps Mike
Nov 29, 2014 | 1992 Nissan Sentra 4 Door
42 inch 2008 yardman model 13AO772G055 ceck belts wont stay on.
check your tension springs one may be missing
May 31, 2014 | Yard Man Garden
Seat adjustment
Most of the seat backrest adjustments I have seen are via a strap attached to each side of the backrest uprights with a quick connect buckle and/or a slide through buckle like on a backpack, photo attached. maybe you could make something like this out of a old school bag strap. good luck. be safe :-)
Feb 07, 2014 | Peg Perego Milano XL Stroller
Needle string wont stay connected
You are missing one of the steps in your threading pattern. Sometimes it is going the wrong direction when threading the machine. Check your owners manual or go on line to the manufactures website and it will give you tips on what to do.
Sep 22, 2012 | Euro-Pro 1260DX Mechanical Sewing Machine
Imaginext batcave elevator string came out
I had the same issue, my son used his all of half a day and the elevator stopped working. If you take the top of the cave off, and unscrew it from the elevator shaft you will see a black wheel. The string needs to be wrapped around this twice, there should be very little play in the string. What I had to do was take out the 3 screws that held it to the knob on top, then wrap the string back around the wheel making sure not to tangle the string more. once the string is wrapped 2 times you can reassemble.
Dec 18, 2011 | Toys
The weedeater string part below the Gaurd fell off I disconected the shaft and put the blower attachment on and it works fine. Is it the string head that's bad or the inside cable orthe coplete...
The part below the guard is designed to come off for cleaning and restringing, as long as you still have all the parts, you just need to put it back together and it will be fine.
Jun 30, 2011 | Garden
Have to start on starting fluid, won't stay running. have replaced gas line and filter and primer bulb. What next?
You will have to pull your head to see if the valves are seating. If the exhaust valve is not seating it will send blow back through the carb.
Jul 17, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
CCD-TRV608
You are missing pinch roller lock, its like piece of plastic tube 2 or 3mm (1/8 inch)
This part is not available individually as you need to purchase complete "pinch roller assy" and fixing it requires skills and experience of camera repair.
Jan 30, 2009 | Sony Handycam CCD-TRV608 Camcorder
Monitor comes on but wont show picture
You should make sure the cable is plugged into the video port on the back of the tower. Also, if you have more than one video card, ie an "onboard card" and another card that was added later, try alternating one to the other and see if the other one works. You can identify video ports by finding the blue pentagonal plug. It also will be the only plug that your monitor cable fits into (that is describing a VGA cable, a white cable is a DVI cable and is even easier to identify.) You might also want to make sure the video card wasnt jostled out of place. The final solution could be you have developed some bad memory modules, or the memory was jostled out of its slot during the move.
Jan 03, 2009 | Dell Computers & Internet
Put back together
2 clips go in top center on back. one clip on each side by handle swivel points. also there is a string you thread underneath th front. Hope that helps
Nov 10, 2007 | Evenflo Aura Traditions Travel System...
Graco Alano Travel System 7F08DSW3 Stroller Logo
266 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
