Question about InFocus Office Equipment & Supplies
Picture from infocus DLP x1 is too yellow. Has been restored to factory defaults, bulb and lens are clean. Except for the greenish/yellow image it functions well. I reset the hour counter before checking by accident so no idea how many hours but most likely quite high, it's used in a school.
  • xilr8_99 Sep 09, 2009
    Turns out it was a bad cable, replaced the RGB cable and its working fine now.
  • 2,237 Answers
The colorwheel is coated with dust and baked on by the lamp. if it was an x2, i'd say replace the colorwheel. but the x1's colorwheel is not listed as an individual part, so you'd have to purchase the entire optical engine. with that in mind, i recomend cleaning it off (which normally is not considered good practice) with a lint-free microfiber cloth and no cleaners. but in order to get to it, you need to remove the cover, front and rear panels, and unscrew the colorwheel mount. you should have just enough room to gently spin it and lightly clean it. if you break off one of the segments, you're screwed.
Posted on Sep 09, 2009
Model x1. Why does picture have white spots at the top of the screen?
If the projector is a DLP then it will probably be the DMD chip. The white spots are caused by damaged pixels.
Jan 28, 2016 | InFocus Office Equipment & Supplies
The bulb works but I can't get an image
is the projecting image black or what??
what is being projected actually??
have you checked the lens section?
Aug 11, 2008 | Apple InFocus X1 Multimedia Projector
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
Rca input is broken on my infocus x1 bought vga adaptor to rca and i get no image is there some reason why it won't pick up vga connection
is the rca port broken or just not getting a signal? if it's truely broken, replace or repair the main board. if it's just a signal issue, reset the settings to factory default. try hooking up your computer and see if that works.
Mar 12, 2010 | InFocus X1 Multimedia Projector
Infocus X1 Projector started with 3 blinking red lights.
Its due to lamp Ballast power supply is faulty,it need to repair or replace otherwise again it will damage Lamp so be careful
Mar 09, 2010 | InFocus X1 Multimedia Projector
Black and white specks from InFocus X1 projector
if you can get a menu when you press the menu button, reset the settings to factory default. if you don't get a menu, the color wheel or the dmd chip is bad. either way, you'll have to replace the entire optical engine. and unfortunately, infocus no longer has any more in stock.
Sep 06, 2009 | InFocus X1 Multimedia Projector
Infocus X1a no picture, solid green LED
if the lamp is new, it could be the power supply (the ballast is built in to the ps). but make sure you have the right lamp. the X1 and X1a have an sp-lamp-019 and the similar X2 and X3 have an sp-lamp-018. the lamps are almost identical except for the wire configuration on the lamp plug. make sure the wires in the plug match the positions in the socket. also, when you turn it on, if you don't hear a high pitch squeal, the colorwheel is not working. and if that isn't working, the lamp won't either. also check to see if the lamp door is closing properly and hitting the switch at the top of the opening.
Jul 12, 2009 | InFocus X1a DLP Projector
Infocus LP 70 projects a blurred display
Go to control panel and reset hardware configs that way.
Jun 29, 2009 | InFocus LP 70 Multimedia Projector
Black and white image on infocus x3
first reset the settings to factory default (menu, settings). if that changes nothing and the colorwheel is still in tact, the main board is bad.
May 07, 2008 | InFocus X3 DLP Projector1600 ANSI Lumens,...
Blurring
This can be a fault with the lens or the imager. It is hard to know without doing some tests, and trying a new lens and a new imager.
Jerry G.
Apr 28, 2008 | InFocus X1 Multimedia Projector
367 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
