Question about Biostar P4VMA-M Motherboard
Warpspeeder software I HAVE A BIOSTAR BOARD THAT CAME WITH THE WARPSPEEDER UTILITY HOWEVER THE PROGRAM ONLY READS THE CPU SPEED IVE HAD THE COMPUTER OCED BEFORE WITH THIS UTILITY ON ANOTHER BOARD THE WEBSITE SAYS ITS SUPPORTED. OR CAN I DO IT MANUALLY ALOT OF BIOS SETTINGS ARE LOCKED THE BOARD IS A BIOSTAR P4VMAM. I HAVE A 3.4 PRESCOTT THATS HIT 3.8 BEFORE. HELP PLEASE.
  • hughdog Jan 27, 2008
    I downloaded it. It will oc the board. Im having trouble figuring out the right pll setup for the board any idea what work best? different selections change the values on the clocks and the support link says clock gen will be back soon. When it comes to oc im very inexperenced.
    Novelist:
  • 113 Answers
Some programs will not function on specific types of motherboard, and this may be the case here. Perhaps clockgen would work instead?
Posted on Jan 26, 2008
  • Phil
    Phil Jan 27, 2008
    I'm afraid that I don't know this particular mobo, so don't know what to suggest for particular speeds, but you can get clockgen here:
    http://www.techpowerup.com/downloads/248...
I have desktop computer having biostar mother board model M6TWG having intel cpu Pentium III 550 Mhz.
to use win 7 2gb of ram is reccomended, in any case the cpu will be too slow. try a linux light distro instead. bye
Apr 08, 2014 | Computers & Internet
Help please
it could be the heatsink on cpu
May 04, 2013 | Biostar MCP6P-M2 Motherboard - v6.0,...
Cpu fan not turning on
must be the pulse width modulator (PWM) circuits that control the fan, I'm afraid there's nothing you can do with that unless you work for the manufacturer, but you can get converters so that you can hook the fans up to the power supply, this should be a good fix until you get a new board!
Feb 22, 2013 | Biostar Computers & Internet
WHAT IS MAX CPU SUPORT OF P4M800-M7A ( above 2.6GH )
Select the "Start Menu."
Click to select "Control Panel." This will open a new window with several clickable options.
Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel
Click to select "System" from the new list of options
Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer.
Checking the Stock CPU Speed in Windows XP
Click the "Start Menu.
Right-click on "My Computer."
Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window.
Check the CPU rating as listed underneath the "Computer" heading.
Determining Real-Time CPU Speed
Go to CPU Speed Professional's website (see Resources) and download "CPU Speed Professional."
While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website.
Install the recently downloaded
" http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html "
file by double-clicking on it and following on-screen prompts to complete the automated install procedure.
Open CPU Speed Professional.
Click "Test Your Speed" on the main program interface.
A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension.
hope this helps
Oct 10, 2012 | Biostar P4M800-M7A Motherboard
I have bfg 9800gt it wont boot .. just puts monitor to sleep ... am2 biostar mother 450 watt power supply 3gb ram triple 3.0 amd cpu
ive had a similar problem before. in the BIOS there somewhere, there is an option to make your computer use the ON BOARD VGA, or to use the PCXI. which ever one is selected is the one that the computer will use. if you can change this option in the BIOS, you might be able to use your video card.
Jun 28, 2012 | BFG Technologies GeForce 9800 GT, (1 GB)...
My cpu fan's speed is very high. i will produce too much noice. can i reduce my fan's speed?? if i reduced that then what happened?? is there any problem????
On my computer when I first power up the display screen gives me the main board details and an option to change settings on it by pressing an F Key. Does your computer do the same? If it does you should press the key and it will give you the options to control and alter things like fan speeds. Don't forget to check if dust or something else is causing the noise.
Sep 06, 2009 | Biostar P4M800-M7A Motherboard
Dual core E2160 1.8ghz doesnot display actual speed
i think the reason for not using 800fsb is your memory. make sure that you use ram that supports 800 fsb (ddr2-800).
as i don't have the manual i describe you another problem that may be the reason if you already use ddr2-800 ram -> on some mainboards the fsb is rated down when a defined level of memory built in is reached. please check your manual if your board has such a limitation.
Jul 26, 2009 | Biostar P4M890-M7 Motherboard
How do i overclock my machine?
there is alot more...and the risk/reward is what it is all about ..read up and get a good monitoring program and go have fun ..........
http://www.tomshardware.com/reviews/Components,1/CPU,1/
Nov 09, 2008 | Computers & Internet
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
Motherboard
This could be several issues. You need to be much more specific on exactly what you done and what you installed. No video boot could be the following:
1)Memory clock speed not compatible- Say board only see clock speeds of 200,266,333mhz but you installed 400mhz CL or the bios is not set to auto mem cl speed and you need to manually change mem clock speed.
2)Your CPU, memory, or video card not fully inserted
3)Memory module of video no good if it has onboard mem cells
4)You forgot to plug in the yellow/black CPU connector on the board sending no power to the cpu
5)CPU pin bent on install or not seated correctly
I could go on and on but there are a few issues that cause no video boot so double check all you cards and connections.
Oct 16, 2007 | Biostar K8M800-M7A Motherboard
Biostar P4VMA-M Motherboard Logo
2,836 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
