Question about Canon imageCLASS D880 All-In-One Laser Printer
I had an unusual paper jam and since. I think a small piece of paper may be still jammed in somewhere because when i try to print or make a copy i hear a squeek and the copies come out competely covered in small grey spots... what can i do?
  • donna927 Sep 09, 2009
    I tried opened and cleaned out paper tray under toner container and problem persists.
    I removed ink toner cartridge and cleaned out cannot see paper..
  • 4,281 Answers
For that pull the ink cartridge then check for paper small piece there should be stuck piece of paper.
Also check in back side of printer.
If you can't find and still face error then you have to open fuser assebely.
Sometimes taplone tap damaged on roller so it gives bed print.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 09, 2009
  • 1,555 Answers
Printers and copiers are designed in such a way that if any paper is stuck inside due to mechanical or electrical failure it can be removed easilly. One should always remove paper very gently and from the side which is having the largest portion of paper. At present you shall remove the paper tray. Remove the power cable. Open up the paper delivery side if its closed with flap. Open manual paper feed tray. Blow the machine from the manual feed side towards paper delivery on medium blower from your vaccum cleaner. If this is not sorting out the trouble and still you are hearing squeek sound you should know that its not a paper stuck inside its either a stapler pin or something hard. So don't use your machine any further in order to save the printing head and call the mechanic for removing the FOD.
Samsung scx-4521f "paer jam 2"_ i've checked paper inside but i can't see any thing is jammed. if i turn off and on that time 1 paper will be printer ofter one same problem is repete. any advice sir
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Jun 02, 2014 | Samsung SCX 4521F All-In-One Laser Printer
FS-3900DN rear unit paper jam
Hello, Power down the unit.Unplug power from wall. Power back up, if the error still happens, there is a small piece of paper somewhere, take toner out and look, or pull down back cover and look in there.
May 22, 2014 | Kyocera FS Office Equipment & Supplies
Rec. Paper Jam slide platen left
There may still be a small sliver of paper somewhere along the paper path. It only takes one small piece to interfere with the mechanism that detects jams and causes the copier to stop working. Since the copier gives you an indication of where the jam is occurring, I would focus my attention in that area, removing trays, using a small flashlight to get a really good look inside.
Jan 07, 2010 | Canon SmartBase PC1270D All-In-One Laser...
Paper jam error but no paper in printer
make sure their isn't a small piece somewhere holding it up. if not try turning off the printer and then unplugging it. if that doesn't work contact the manufacturer because this may be a common issue they have .
May 07, 2009 | Office Equipment & Supplies
Images on copies
your teflon sleve triangle cut
replace fuser teflon sleeve
Feb 22, 2008 | HP Color LaserJet 2600n Printer
Canon
You prob have a few small pieces of photo paper jammed in the printer somewhere. Try to take something small that you can push through the printer to make sure there is nothing hidden jamming the printer.
Jan 22, 2008 | Computers & Internet
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
Paper jam message will not go off - so unable to print . there does not appesr to be anything in the printer. have tried every thing i can think of. help ireally need to print
Do a careful check for anything stuck in the printer- a small piece of paper, paper clip, or even a small piece of broken plastic from the printer itself. Anything that can jam up the works, or hold a paper sense sensor in an activated position can give you a problem like this. Also, the paper sensor itself could have a problem. This sensor is in the paper path somewhere.
Jun 11, 2007 | HP Photosmart C4180 All-In-One InkJet...
Canon imageCLASS D880 All-In-One Laser Printer Logo
21 people viewed this question
old marine
old marine
