Question about Brother DCP 115C All-In-One InkJet Printer
The black ink cartridge I got from Abacus has leaked out unknown to me but has stained the shelf underneath, for a while it had been saying black near empty, I ignored it as I knew I had just changed it, but when I put in a new red & yellow it kept telling me they werent in .
Big black vertical line on the back of the paper. Have cleaned the nozzle several times as directed by online instructions, but still ink line tehre, you say clean the nozzle with a stick, but you dont say...
Any ink on back of paper is a stain and not a print. So open the cover and look carefully and well into the printer, the path of the paper, and you will most likely see ink stain about the area where the stain occurs and wipe thoroughly with tissue a soft cloth.
Good luck 7 God bless!
Mar 03, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Cannon MP220 displays colour ink vol unknown
For the Canon Pixma MP220, I kept getting a message saying "Col Ink Vol Unknown" after refilling and replacing a cartridge. After reading some of the other responses it appears as though Canon cartridges contain internal chips that prevent you from using them after they have been refilled. However, I tried a few things and this is what worked for me.
1. Insert your refilled Canon cartridge like normal, close the lid.
2. The Error message "Col Ink Vol Unknown" should still appear.
3. Use the "Menu" button to scroll to "Maintenance" (press "Menu" 8 times to find it), then press "OK" to conduct a "Nozzle Check" and a coloured test will print out.
4. The Error message will still appear but you will be able to print using colour AND with black and white. For some silly reason the Canon Pixma MP220 won't print using black and white if there is no coloured ink...
Hope this helps!
Feb 03, 2010 | Canon Office Equipment & Supplies
Printer using a black cartridge in one week. Loosing ink somewher
Unless you can find a leak or have stained paper, ink is not likely to be leaking out. Have you used non-OEM cartridges? Are you printing pictures? Did the refill say it was a PHOTO pak, etc? When you buy ink, look at the number of pages the new cart. will print before you purchase.
Apr 23, 2009 | HP DeskJet 6450 Printer
Leaking Black Colour
REPLACE THE PRINTER AND SAVE YOURSELF A HUGE MESS
Understand when I suggest replacing the printer, it isn't that you can't fix it or that I'm not answering your question. But to do so will require cleaning every inch of the internal components. The ink will stain everything it touches and you'll need a smock, a work area, and probably gloves.
See what happens is that where the print head parks there is an ink absorber and below it is an ink well. The ink absorber is a sponge like arm that cleans off the cartridge and the well catches the loose ink. Inkjet printers are for the most part not designed to last past a few years, so few printers have a method for emptying these. When they become full the printer will start leaking ink in torrents but will continue to function normally for quite a while until it fills every nook and cranny of the printer. While all you notice is a sightly higher consumption of ink.
By the time you start visibly seeing the ink come out of the printer, the inside is a huge mess, and when I say huge I mean without cursing, words just can't express how nasty and ink smeared it is.
Aug 04, 2008 | HP Photosmart C6180 All-In-One InkJet...
Ink Leaks
Richard,
I dont understand "inverting". Do you mean turning the machine around (180 degree) to see the bottom of the machine?
Anyway, inkjets used to stain after a while. This is because of serveral reasons: the ink absorber felt is getting wet due to the cleaning cycles, some ink will splash from the printhead, ink will flow back from ph to cart etc.
Do you refilled the original carts or do you use generic carts? The latter one do NOT keep the ink inside the cart when turing the machine to bottom (e.g. for Postal sending) due to diffrent construction.
You should use original carts for refill. Make sure the plastic support secures the carts.
Only original carts wont leak!
Mar 05, 2008 | Brother MFC 420CN All-In-One InkJet...
Does not accept black ink cartridges
Did you use generic ink? These generic carts are different (no seal to prevent staining). This carts stain the led control circuit board which has to be replaced by a new one (the spare part is only avaiable as the whole ink cart holder incl. led board and tubes).
There is no way to do a short fix, sorry!
Nov 28, 2007 | Brother MFC 240C All-In-One InkJet Printer
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Black ink not working; but colors are
Use a original brother ink cart. Do the cleaning twice. If there is no more black blocks to see, the printhead is crashed!
Aug 25, 2007 | Brother MFC 420CN All-In-One InkJet...
Ink problems col vol unknown and wont print
Something that worked for me, I opened the Conon MX310. took out both cartridges, and for 10 seconds I held the Reset. put the cartridges back in, closed the lid, and again, for another 10 seconds held the reset. SLOW seconds. this reset, ink levels recognised,, and it's working as it should be.
Regards
Shane (AKA Reef_Lex)
Jul 27, 2007 | Canon PIXMA MP170 All-In-One InkJet...
Brother DCP 115C All-In-One InkJet Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
