Question about ASUS A7N8X Motherboard
I've had this mother board, asus A7N8X, for like one or two years now. Today I noticed that my processor was almost overheated so I decided to change it to another one that I had. I know that all my three processors works properly but when I putted it into my motherboard it just started up and then it shutted down again. So after awhile of trying I thought that maybe it was the processor, so I changed again, but with same problem. I've been trying to reset the bios and change different stuff in it for more than four hours, but with no result... What should I do?
  • 1,879 Answers
Check the cooling system, else it's the board gone bad
Posted on Sep 09, 2009
  • 76 Answers
Have you tried to pull the battery itself for 15-20 minutes and left the motherboard unplugged? Also you could visually inspect make sure no capcitors are expanded. I have a A7N8X-E that gave me problems whenever I tried to change settings, and I ended up RMA-ing like 4 boards. It could potentially be as bad as that.
Mother board update
Well that can depend on a number of factors like how much you are willing to pay.
Logon to newegg.com or zipzoomfly.com and search through their motherboards for ones that match your processor. pick one that has the features you want. Im partial to Asus boards so id find one of those that would match that processor. They list which processors will work with them so it really is pretty easy. zipzoom is my personal fav.
Mar 09, 2010 | Intel Desktop Board D845BGL Motherboard
I need motherboard sound drivers need fix
try googling the model number, that usually works for me
Feb 24, 2010 | ASUS A7N8X Motherboard
My AMD 3200+ 400/333 chip has died, what can I replace it with? The motherboard is an Asus A7N8X.
Anything in AMDs Socket A line of processors should work.
The AMD Athlon XP 3200 was one of the best processors that would work in that board. Good luck finding one though.
Oct 10, 2009 | AMD Athlon XP 3200+ 400MHz FSB CPU...
Computer will not start
first you connect your harddisk data cable to mother board
connect your hard disk powercode using smps
connect smps 24pine connector threw mother board
connect 12v connector threw mother board
connect cpu&external fan connections
also connect the front panel connections on mother board using mother board details
Jun 17, 2009 | ASUS A7N8X Motherboard
Can i replace supreme fx with fxII on my asus a7n8x-e deluxe
mother board as class as form factor this is a standard connector and mounting style if the two board you are trying to replace are the samr form factor then yes it should fit make sure the all you parts like the cpu and the video are compatable. if you using a agp video card then make sure the board has an agp slot and it the correct speed bou other then those type of checks it should work if thing match up the form factor
Jun 10, 2009 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
I have an asus a7n8x-la mother board. It ran fine except the cpu cooling fan would speed up and the cpu heat sinc was very warm as compared to others. Finally it would not boot or go to post with the beep....
First of all set the BIOS default.
i think somebody change your Bios settings like-- over clocking or speeding fan etc etc.
add comment for further assistance.
Good Luck!
neo
Feb 27, 2009 | ASUS A7N8X-E Deluxe : ATX Socket A FSB400...
Processor
This are the compatible with this motherboard : Compatible Processors - Athlon, Duron, Athlon XP , Processor Socket - Socket A , Chipset Type - NVidia nForce2 400 , Max Bus Speed - 400 MHz .
This is the complete specs for this motherboard , check this link http://www.shopping.com/xPF-Asustek-A7N8X-X-Socket-A-LAN-nVIDIA-Audio
Don't forget to rate the solution FIXYA thank you.......
Oct 18, 2008 | ASUS A7V8X Motherboard
Reg-problems facing while operating computer
check bios setup (pres del or f10 at startup) for cpu speed if speed is mentioned less than actual then change to the right value. if cpu speed is ok in bios then speed info might have changed from registry. my computer>hkey_local_machine>hardware>description>system>central processor>hightlight o folder>on the right pane select processor name status> change this to original value.
Oct 15, 2007 | ASUS A7N8X-E Deluxe NForce 2 Ultra 400...
ASUS A7N8X Motherboard Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
