Question about Archos 604 WiFi Digital Media Player
Archos Have Archos 604. While in DVR station, stopped working. Cannot get it to turn on either in it or with USB cord and computer. Any suggestions??
  • robertmath Dec 12, 2007
    Removed battery-no help. Still will not turn on, either alone with battery or in charging stand.
  • ananthr Dec 27, 2007
    Baught new Archos and its switching on and tried to charge it but it still the same
Junk it... throw it in the trash bin
Posted on Dec 20, 2007
  • 4,402 Answers
Does it have a battery? remove it
does it have a reset?
Posted on Dec 10, 2007
  • Cary Farah
    Cary Farah Dec 12, 2007
    remove the battery and press the “RESET” button.
Can I charge archos 604 batteries using dvr station and power outlet?
yes you can, however the battery must be inserted into the 604. Simply dock the 604, ensure the dvr is turned on and the 604 will automatically turn on and start charging.
Sep 09, 2010 | Archos 604 Digital Media Player
I need a manual to operate the remote control for the Archos DVR Station for 604, 504& 404. Thank you.
user manual:
connection sheet (USA):
connection sheet (Europe):
Aug 18, 2010 | Archos DVR Station MP3 Player
Lines across tv when using archos with dvr station, fine when not using on tv
SOunds like a problem with the connection between the dvr station and the tv. Ensure all connections are insered fully and dust free. Also ensure that you have set the output signal to PAL if using in Europe - do this via the setup menu
Aug 08, 2010 | Archos 604 Digital Media Player
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
Dvr docking station
I had the problem that the record feature was not available in or out of the docking station and therefore i could not record. Archos connector on bottom of unit senses a change in the resistance of the device it's docked with and knows if it's the DVR station or not.
Turned out to be a hardware fault - i had to RMA both the Archos and the docking station (while in warranty) and Archos fixed it/them.
That may not help you much.
PS: I think i zapped my DVR station with static one day and that might have been the original cause.
Dec 31, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 will not restart
i had this problem recently when charging on the DVR docking station, i switched it off, took the battery off, left it for a shirt time then pressed the reset, it took a few attempts but eventually it restarted
Aug 09, 2008 | Archos 604 Digital Media Player
Archos 604 (not WiFi) connection to TV without the DVR station
HI, bought the following off ebay and they worked just fine. I to thought that the socket on the right side was audio only. Can't get a picture via my DVR (may be a fault) however this item works great.
Jun 06, 2008 | Archos 604 WiFi Digital Media Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
If the camera accessory is not functioning correctly you may need to check a few things before considering a return of the camera unit. First, read the included documentation for the Archos 604 and the camera accessory and make sure they are compatible. If you are talking about a digital camera that you take photos with, you need the DVR Docking Station, or the Traveling A/V Docking Station for camera/usb connectivity. Both of these accessories are available at I suggest that if you want your problem answered better, you need to be more detailed in explaining it, and have more details as to what difficulties you're having.
Aug 26, 2007 | Archos 604 Digital Media Player
Archos 604 WiFi Digital Media Player Logo
78 people viewed this question
Top Archos Audio Players & Recorders Experts
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
