Question about Garden
Sears lawn tractor model #917.273811 6 month old battery keeps going dead i put a volt meter on cables at full throtle only reads 12.66 dont change at low throtle any thoughts on what is happening thanks george
  • 69 Answers
Sounds like your voltage regulator may be bad. Voltage at full throttle should be around 13-14v to properly charge the battery.
Posted on Sep 09, 2009
How can tell if a silanoid bad on my riding mower
After assuring battery is charged and all electrical connections are clean and tight, you can try this,
If your tractor has the external solenoid (separate from the starter), you can by pass this solenoid by jump starting the starter with booster cables.
Negative cable will go on neg post of battery to a good ground on engine and then positive cable on positive post of battery, then just touch the other positive end to positive starter post (where the large cable is connected from solenoid). If the starter engages, chances are the the solenoid is bad or could be ignition switch is bad.
Oct 02, 2014 | Garden
Can alternator put out 14.2 volts but not enough amps to charge battery and turn off dattery light?
Yes and no.
It sounds like you have a wiring problem.
The alternator output could be 14 volts and only one or two amps, but that would be enough to kill the warning light. Its more likely the alternator is charging but the current is not reaching the battery.
Aug 26, 2014 | GMC Envoy Cars & Trucks
Why does my tractor keep draining the battery?
get a DC volt meter and check voltage at battery post before starting tractor
start tractor and again check voltage at battery posts . you should be getting between 13 & 15 volts,if not charging circuit is not working.
Its either a voltage regulator problem or a stator (located under flywheel) problem.
Stator produces AC voltage to regulator so you need to set your volt meter to AC ,most stators have a plug exposed insert red and black lead of meter into each side of plug, you should read around 23 to 26 volts AC if no reading stator is opened (bad). The PTO clutch requires a full 12 volts to stay engaged. you could have a bad battery bad cell .have seen new batteries be bad.
Nov 13, 2017 | Garden
Battery keeps going dead
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Nov 02, 2013 | Harley Davidson FXST Softail Standard...
**Help** I have a Sears Craftsman 18hp Briggs/Stratton riding tractor, about 10 years old. Just put a new battery in last week. Went to start this morning and battery was dead. The red cable that goes to...
Yes it very well could be the starter solenoid, with a digital volt/ ohm meter and the battery disconnected place the positive lead on the positive test lead . With the meter on ohms take the negative lead and touch the frame or engine . This will confirm weather or not you have a short to frame. If the meter reads 0.00 disconnect the starter from the system by removing the positive and ignition wires from th starter . Now individualy test each wire removed from the starter in the same process as above if ohm meter read ol ( over limit) the starter would be the best place to start. If the meter reads 0.00 would suggest there are other issues in the circuit and the starter may not be at fault.
Oct 14, 2013 | Craftsman 42" Briggs Stratton 20 hp Gas...
1998 heritage softtail battery going dead
Sep 08, 2012 | Harley Davidson FLSTC Heritage Softail...
I need to find out what the voltage output and the miliamp output is on a toro z4220 mower my battery keeps going dead i have replaced it once already Thank yoy
You should have around 13.1 volts at the battery as the engine runs. If its 12 volts or lower - check or replace the voltage regulator. To check the regulator, stop engine, remove regulator plug, get a ohm meter and put the black lead to any ground,and touch the red lead to all the terminals one by one on the voltage regulator - you should get 3 readings - one lower than the other. If you dont get any readings - the regulator is definitely bad
Don in Baltimore
May 02, 2011 | kawasaki 48'' Toro Com Zero Turn Lawn...
I have a Husqvarna 21 HP Lawn Tractor and I went out to start it and the battery was totally dead, so I jump started it. It started but died out a couple times. So I got it going again and drove it up the...
The electric clutch needs full power in the battery to stay engaged. I would recommend you check your charging system before replacing the battery. Put a digital volt meter across the + and - terminals of the battery and while running at about 1/2 throttle you should be over 13 volts DC. Probably around 13.5 or so. If not you have a charging problem. Lawn mower batteries I have seen seem to last only 2-3 years. I would also recommend a trickle charger for extended periods of non use. Don't forget the Stabil also.
Hope this helps.
Jun 27, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Craftsman 21hp, 48" lawn tractor, electric start, automatic trans
The alternator is built into the starter. Check with a volt meter to see if you have at least +13v while mower engine is running. Could be a bad battery.
Jun 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere LX188 lawn tractor battery discharge light remaining o
Check the brown wire feeding your voltage regulator,its between batt and steering wheel behind left side of frame.LX100 series machines had a problem with brown wire not fully contacting terminal in regulator.You will know you had bad contact if plastic is discolored.
Sep 23, 2009 | Garden
Garden Logo
248 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
