Water appears in drum after wash cycle is finished.
Noticing water in drum - intermittent - seems to ''pool up'' overnight. The water is slightly murky and very smelly! Ran the cleaning cycle to help remove the awful smell, and presto, no more water pooling for about 6 weeks. Then, there it is again - about 1-2 cups in the bottom of the drum. Ran the clean cycle again, and it's gone for the time being. What is going on? .
    Problem Solver:
  • 17 Answers
If you remove the front cover there is a drain plug that holds change and lint paperclips etc, it fills up and gets plugged and wont go throught the drainig pump. if you find this and clean it out you will be good for another 6 months...its important to check pockets before washing
Posted on Sep 09, 2009
  • 11,896 Answers
This is normal. These machines always hold a slight amount of water.
Remove smelly odour from swimming pool water
clean filter and run pool continuously for about a week, check the water chemicals with a test kit to make sure it has what it needs to get it stable
Dec 24, 2014 | Pool & Spa
Pool water stays murky.Hard to get water sparkly clean.above ground pool
clean filters and super shock after clear then clean filters again
Jul 15, 2014 | Pool & Spa
LG dishwasher stinks since new model #LDF6920ST
list given is the wrong stuff to clean any dishwasher
LG LDF6920ST Dishwasher
thats an old dishwasher now
use recommended dish washer cleaners regularly
off the shelf deodoriser and sanitizes on an full empty cycle
check the filter at the bottom is kept clean each load clean
temp of wash water may no be enough
helps if you wash off any food stuffs on articals with hot water before placing in the dishwasher
Apr 06, 2017 | LG Dishwashers
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Water is greenish brown
run run run that pump 24/7 clean clean that filter check ph first then balance other chems it will take awhile with well water to clear
Jul 14, 2017 | Intex Automatic Salt Water System for ...
Water in washing machine drum
I shall give you some tips for cleaning the washing machine and clearing the smell
check this link:
http://www.espares.co.uk/advice/washing-machines/a/7/1182/smelly-washing-machine.html
Oct 19, 2011 | Washing Machines
Dolphin pool cleaner stops working after a 15 to 30 minutes. Even though the cycle time is set to 8 hours. How can I fix ?
It sounds like you might have a problem with the impeller or drive shaft, which are both common problems with these pool cleaners. Clean around your impeller and your wheels, axles, etc. If these do not cure your problem, it is probably an issue with your electrical system.
Jul 30, 2010 | Dolphin Maytronics Advantage
Smelly Water Draining
Try getting the new whirlpool affresh washer tablets. They clean the mold and are supposed to make everything in the washer smell better and keep it clean. They are only around 10 bucks and is worth a shot to clean your smelly drain.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Clothes smell musty
The big door seal is probably the problem. Put on gloves and using a solution of Laundry detregent and hot water and rags, carefully wipe clean all the folds of the seal. It will be icky. Next run a cycle with some detergent and oxyclean or bleach if you have it.
Especially during warm weather, damp clothing left in a front loader mildew slightly very quickly- you can't really see much but you can smell it! So get the clothes in to the dryer immediately. You'll want to relaunder the smelly clothing after you have cleaned the washer.
Good luck to you and Thank You using FiX YA!
Aug 19, 2008 | Kenmore 43052 Front Load Washer
Whirlpool duet front loader washer
Mold and bacteria in your door seal is a symptom of problems deeper inside the unit. All washers - not just Whirlpool, have this problem. The area of worst buildup is always on the inside of the plastic outer tub just above the normal waterline where suds and soiled water splash up and don't get rinsed out. To clean this problem area add 1 or 2 caps of smelly washer cleaner to a full load of laundry. The added bulk of the laundry will raise the water level to include the "splash area". Intermittently pause to soak more extreme cases.
Aug 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
121 people viewed this question
Top Washing Machines Experts
