Question about Maytag Dryers
My dryer heats,tumbles,but takes several cycles to dry a load(small).Not much air coming out of vent and have cleaned vent out.Any ideas?
  • 1,000 Answers
The fan that pulls the hot air through the dryer and pushes the exhaust out through the vent hose is plugged with lint. You will want to remove the cover on the fan and manually clean the fan out. I had the same problem with my dryer, I was astounded by the amount of lint that was trapped in the fan.
Also look inside the cloths drum on the back wall and make certain the hole in that wall are not clogged with lint also. Use a flash light and make sure the hole are perfectly clean.
Good luck, clean it all out and let me know.
Regards,
Posted on Sep 09, 2009
Takes several cycles to dry
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Dryer gets low heat takes three cycles to dry a small load, I checked the gas flow and it comes on and burns blue but must not cycle right because the clothes are not drying. I have never repaired a...
If a dryer is heating but takes to long to dry you can bet the dryer has a air flow problem. I would check the dryer vent first for restrictions due to lint build up or kinks. Remove the dryer vent and clean the lint out. Also check the outside flapper on the end of the dryer vent to make sure it's free of lint and able to open all the way.
It also a good idea to take the dryer apart and check around the blower/fan housing for lint build up.
Aug 07, 2011 | Dryers
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
No Heat: The dryer has been taking more than one cycle to dry the clothes for several months, but today there was a very small load in the dryer and it took 4 cycles to just get dry enough to take out of...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 12, 2010 | Dryers
Kenmore 600 dryer tumbling & heating, but not drying
Several reasonings. Step One make certain that you have 220 volts coming to your outlet. It takes 110 for the motor, and it takes 110 for the heating elements. If you have a volt meter that would be the best way to do that. Take the red and stick it in to the long part, and the black lead to the ground. Fuse houses was bad about this. Step Two it could be the elements are kicking off too soon. That is usually a sign of almost blown element. Step Three the heat sensor for the element prematurely kicking off the element.
Aug 10, 2009 | Kenmore 600 7965 Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
Dryers Logo
51 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
