Question about Canon DR-2580C Path-Through Scanner
Installed driver twice for Canon DR-2050c. Still
Installed driver twice for Canon DR-2050c. Still having a problem where after a few scans the computer will lock up and then I will get a message "the device could not be locked. Check that another application isn't using the device (-4630)." It doesn't seem to "see" the scanner after a few uses.
  • 490 Answers
Pls run checkdisc/scandisk on your Comp. Your OS may be corrupted. Just to verify try scanning by connecting to a formatted newly loaded OS Computer.
S. Mohan
Posted on Sep 10, 2009
  • 1 more comment
  • Kyle_MIETech Jan 17, 2011
    You could have a scan panel in taskbar. Check your startup in MSconfig and take scan panel off of startup. It isn't because the OS is corrupt.
  • Cori Huggins
    Cori Huggins Nov 19, 2013
    Thanks Kyle, checking MSconfig revealed old Fujitsu utilities that we interfering with the Canon scanner!
  • krystal
    krystal Dec 23, 2013
    how do you check what is interfering with the scanner? I tried I dont know what to look for or how to get in there. please help
Canon 2050c scanner replaced rollers still scanning 1 page per minute
please check the resolution it may happen higher the resoulation time take for scanning is more.
if problem persists then please change photo IC
Aug 19, 2009 | Canon DR-2050C Path-Through Scanner
Dr-2050c multi-page document stops scanning after one or a few pages, inconsistently. Feed lever is down in the multi-page position. Feeder tries to separate the pages: sometimes it succeeds. Document...
If the scanner is scanning but stops after a few pages either it could be because of a) There is insufficient disk space (you need to delete unwanted files or direct the comp to store whre there is space) or b) the rubber rollers are not able to separate pages and feed the papers for scanning.(You need to change the rollers)
Jun 08, 2009 | Canon DR-2050C Path-Through Scanner
NOT SCANNING
First check if the driver is installed. Then install CapturePerfect and select proper settings. If the background is dark, select 'Auto' else select an appropriate contrast level. Uncheck multipage so that you will know the pages scanned. If there is no response from the scanner, run Scandisk and try. Also try connecting the scanner to another systems and eliminate if the scanner/Operating system is faulty. If required reinstall OS.
S. Mohan
Jan 06, 2009 | Canon DR-2050C Path-Through Scanner
Canon dr 2050c
i want the driver for canon dr-2050c
Aug 14, 2008 | Canon DR-2050C Path-Through Scanner
DR-2050C Scanner all sheets feed thru only one scans
Do you get an error message after the first scanned image? If not, check your software settings to see if you have the option of single page /multipage scanning. Some software lets the customer choose a single page scan when the SCAN button is pressed.
Check the "Feed Select Lever" to make sure it is in mutifeed position. If not, it will grab all of the docs at once.
Jul 05, 2008 | Canon DR-2050C Path-Through Scanner
DR 2050C
This has something to do the brightness chosen. In the manual mode, if you choose a dark output, the output will have tis area also; if you choose, lighter output, it will omit. In the auto scan mode, the scanner decides what is the best output.
S. Mohan
Dec 19, 2007 | Canon DR-2050C Path-Through Scanner
Canon 2050C scanner
In the software, select 'multipage' option. (Check this box). The output will be collated and provided to you as a single file.
S. Mohan
Feb 08, 2007 | Canon DR-2050C Path-Through Scanner
Canon DR-2580C Path-Through Scanner Logo
4,565 people viewed this question
old marine
old marine
