Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Where do I connect the hose for the hand tools to the unit' on the9514-900
There is a piece that slides out on the front of the waste water compartment. Slide this piece out, place the "v" shaped end of the hose into the compartment, replace the lid and you are good to go.
Posted on Sep 11, 2009
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
How do I close off the hole to use the extension hose?
Some units do not have a close off. Simply connect the hose to the inlet or outlet and use to such up dirt, or dust off components.
Oct 30, 2014 | Shark Bagless Cyclonic Hand Vac, Blue
No suction for the hand tools
If your suction is ok for normal cleaning and bad for just the hand tools then you have a blockage in the flexible hose or the "u pipe" at the bottom of the flexible hose. Un-clip the u pipe and check it for blockage. Un-clip the hose from the vacuum and you should be able to look through it when letting it hang straight down.
Hose removal here
http://www.youtube.com/watch?v=NfZlHIFlwJc
Feb 23, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Can't get my bissel steam cleaner to sucktion
Check on board switch for tools only or vacuum, is switched to vacuum, as majority of vacuum suction power is diverted to hose/ hand held devices. See if vacuum hose has suction as well? The unit may be clogged with carpet fibresas well and the unit may have to be taken apart and cleaned thoroughly.
Apr 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
My hose tools wont pick up. when hose tools unattached suction is fine and will **** my hand fiercely, but once tool attached no suction..... how am i gonna pick up cat hair from seats now?! its a dyson...
I have a DC04 and the hose tools are a open hole.The only reason they want pick up is they are blocked.If you say they are sucking your hand when not attached.Make sure the hose is not blocked by taking off the cover at the front.Allso check the cylinder rubber seal is sealing the dust container.Thats the only problem i had with mine.Good luck.
Jul 31, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Can not figure out how I have to attach the Powered hand Tool
Just got connected it to the main hose and press the switch on
Mar 28, 2009 | Hoover S3765-040 WindTunnel Bagless...
Using stair attachment, ++water leaks onto floor under the unit;
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool properly. Follow
these steps:
1. Attach tool to hose and turn the deep
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
Feb 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Replace the switch that controls hand tools to the upright unit
If that flap isn't moving when you turn the knob for floor or hose, then yes it is broken, part #2136988 is the diverter valve. You will have to remove the top cover, it mounts on the underside of it.
Jul 23, 2008 | Bissell 1699 ProHeat Clear View Upright...
Hoover F7425-900 How to attach hand held cleaner
There is a round door at the top/front of the clear duct on the hood of the unit. You insert the hose there and then connect the small solution hose to a valve that is located on the right side (if you are facing the machine) of the machine, just ahead of the rear wheel.
Mar 21, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Can't get water to spray out of the hand tool nozzle
When you attach the main suction hose to the front of the machine, you also have to connect the soultion hose to a valve located on the side of the machine. When the machine is running, take a small screwdriver and depress the centre of this valve. You should get a spray of water out of the valve which will confirm the valve and pump is working. Now, connect the small solution hose, making sure you push it on all the way. When you pull the trigger on the handle of the hose, you should get spray. If it does not, you may have a plugged nozzle sprayer.
Feb 16, 2008 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
113 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
