Question about NetGear WGR614 Wireless Router
My old 2wire 2701hg-b router went bad and I replaced it. I had a netgear wgr614 attached to it for a second network and now i can not get the netgear to attach although all lighs appear okay Showdave
    Novelist:
    Champion:
  • 210 Answers
Its just locked up as it can't see your old router, 2 resolutions:
If you have have backed up your config settings for the router or you don't have any set then press and hold the reset button for 30 seconds, now let go and power the router off, now power the router off and back on again>this will reset the router back to factory defaults and you now connect back up to the router but you will have to setup your broadband logon again.
The second option is to connect the router via an ethernet cable and reset the router and it should let you connect wirelessly again.
Thanks
Posted on Sep 09, 2009
What steps do I take to configure my 2wire 2701 hg-b to connect directly by ethernet cable to my Directv HD DVR and pick up the dsl signal being transmitted by my primary westell router? Both are wireless...
Connect the cable at both ends and do a red button (inside card door) reset of the DVR. To test the connection, do thus: Menu -> .....setup -> system setup -> network setup -> test connection. If it shows not connected then "reset defaults" and run "connect now"
As a basic security feature the ATT DSL 2Wire 2701HG-B router/gateway requires you to enter its pre-assigned WEP key to connect beyond the unit itself and then to the internet. Since the Direct TV DVR HD24D only does a basic connection without having a place to enter the 2701HG-B WEP key it never actually reaches the internet.
The 2Wire 2701HG-B has the ability for one attached unit to "pass through" its firewall and internal security settings using a so called "DMZplus" mode. I set the HR24D DVR to such a mode within the 2Wire unit and the DVR connected with the internet flawlessly.
Dec 30, 2010 | 2wire (2701HG-B) Wireless Router
Where do i find the essid and key on the 2701HG-B trying to get a HP Photosmart printer to attach
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here for step by step Instructions on how to find the network key
Dec 20, 2009 | 2wire (2701HG-B) Wireless Router
2wire 2701 block port 80
Go to the following link. This is just an example on how to forward ports for limewire. Use the same steps to forward port 80.
http://portforward.com/english/routers/port_forwarding/2wire/2701HG-B/Limewire.htm
If it still doesnt work, try updading the firmware. In case this fails, then we have some issue with the router
regards
Sandeep
Oct 13, 2009 | 2wire 2700HG-B Router (2700HGB)
2wire 2701HG-B: how do I extend it's range?
I purchased Netgear's Wall-Plugged wireless bridge (WGX102 ). Worked very nicely.
Apr 04, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
I need 2wire documentation for turning on the firewall
Just disable the wireless security on your 2wire and change the channel to 11. Then power cycle all your devices including the wireless printer.
Oct 25, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2701HG-B constant power loss
Hard reset the router and reflash or update the firmware.
If still wont work then it will be hardware problem (bad memory).
Oct 03, 2008 | 2wire 2700HG-B Router (2700HGB)
Problem in reconfiguring WGR614 v5 after reset
You should configure the 2wire to a bridged modem for the autentication to work on Netgear.check with your ISP for configuring your 2wire to bridged modem
Cheers !!
Feb 24, 2008 | NetGear WGR614 Wireless Router
Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Dec 12, 2007 | 2wire HomePortalĀ® 1800HW Router...
NetGear WGR614 Wireless Router Logo
214 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
