Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Exactly same as the previous one
Same as the previous persons problem.
  • balacv02 Sep 10, 2009
    Alright, Sorry about that. Here is the problem. HP solution center says 'No HP devices found. Solution center will close now' and it just doesn't work. Tried all tricks suggested by HP. It is stuck and doesn't go away. Reinstalled the software several times after cleaning up everything-No luck so far. Now the PML driver is not seen in the list of services. I hope this helps.
  • Ekse May 11, 2010
    Which person is that from the 12 000 000 that visit the site dayly??
If I Previously Have A Personal Bankruptcy Am I Still Qualified For Business Loans?
Your personal bankruptcy should be a minimum of 4-6 years with respect to the loan products there mustn't be any late payments, charge-offs or collection products in your report because the personal bankruptcy. Lenders need to see you have been financially responsible since declaring personal bankruptcy protection.
Dec 31, 2015 | Computers & Internet
If I've Got A Personal Bankruptcy Previously Am I Still Qualified For Financing?
Your personal bankruptcy should be a minimum of 4-6 years with respect to the lending product there mustn't be any late pays, charge-offs or collection products in your report because the personal bankruptcy. Lenders need to see you have been financially responsible since declaring personal bankruptcy protection.
Jun 03, 2015 | Computers & Internet
How do I unblock a previously blocked person on facebook
  1. Click in the upper-right corner of your homepage and select How do I stop someone from bothering me?
Click View All Blocked Users.
Click Unblocknext to the name of the person you want to unblock.
Feb 05, 2015 | Facebook Computers & Internet
Okey i have a toshiba satellite a105 s2071. it was given to me but the person doesnt have the recovery disk and i tried so many ways to factory recover my notebook and nothing works what can i do????
hello. can you explain exactly what is happening.
Does the bios boot up? Does the operating system start assuming windows xp? Are you looking to recover previous work or a fresh install?
Jun 16, 2011 | Toshiba Sattelite A105-S2071 Notebook
I never open an paypal account just receive a letter from collections for the first time no previous notices my privatively was use what should i do
Call the number on the collections letter and tell them exactly what happened. You did not open the account. They should be able to go back and check for the email address and IP that set up the account and find the person that way. You are not liable unless they can trace it to you actually setting up the account.
Feb 25, 2011 | PayPal Accounts
Wall switch has white, black, red on 1 side and black, black, black on the other side. 3 conductor cable runs from switch to heater, vent light unit. How do I connect the wires at the unit?
First you need to test your wires to find hot wire.
Hot wire connects to black wires or dark screws.
Electricians test the wires before hooking up anything: buy 5$ multimeter from Home depot to check continuity (ohms) on wires of new device, and test wires inside box for hot and neutral wires.
Electricians also make careful note of each wire and what it connect to before taking out old device.
Next step to clearly answer your question: you should add a comment and say:
> what type of device you are replacing.
> exactly what the previous device controlled.
> The screw-color where each wire was located on previous device.
> say what other wires are located inside box you are working on
> Exactly what new device manual says each wire on new device goes to.
Without this information, my response will fill 2 pages trying to cover every possible option.
If you don't want to provide more information, then click at bottom of page to select a paid answerer who can speak to you over the phone > and then you can give that person the information and they will follow through until your project is done.
Dec 13, 2010 | Broan-NuTone FAN CONTROL SWITCH
Having same no reponse on new Olympus FE-3010
Unless it's a generic problem with this model. Lens out and not moving usually means it has been damaged by a knock or has grit/sand in it. When exactly did it stop working, you must know as the lens was out, hence it was on when it stopped working.
Sep 26, 2009 | Cameras
Phone codes :(
Hello Missjay,
My name is Mike. I've been an Expert here at Fixya for over eight months and have never had a problem.
On behalf of the True Experts here at FixYa, I would like to apologize for the post submitted previously.
This person has been previously banned from the site for posting inappropriate content. He chose the weekend for his 'tirade' because he knew there would be minimal staff available to shut him down.
In addition to the account he posted your message with, since Saturday he has created three other accounts that we know of and has used them to post over 100 messages exactly the same as the one you received.
The process of banning him at the IP address level has been initiated. But the process of removing the individual posts will take a while as they must be taken out one by one to maintain the referential integrity of our database.
In the meantime, we have called attention to this persons activities to our colleagues so that those with expertise in the area your problem resides can easily find and address it.
As I said, there are quite a few of these posts and it will take some time to address them all. So please be patient.
Once again, please accept the apologies of FixYa and the True Experts dedicated to making this site possible.
Best Regards,
Mike258
Feb 15, 2009 | Sony Ericsson K800i Cellular Phone
Valid serail no to register
On behalf of the True Experts here at FixYa, I would like to apologize for the posts submitted previously.
Best Regards,
Mike258
Feb 15, 2009 | Adobe Acrobat® 3D 8 Full Version for PC
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
23 people viewed this question
Seeker5211
Seeker5211
