Question about Pioneer Car Audio & Video
I have two of the same amps. Each powering one subwoofer. Through trial and error, Ive found that one amp works with both subs. The other amp doesnt work with either, the power light is also slightly dimmer. I tried switching rca plugs and get nothing still. Im thinking its just not working properly which is a possibility but id like to think its just me.
  • 11,896 Answers
One amp may have the circuit protection circuit on. You will have to turn power off for an hour, check connections, and restart. I like to leave the fuses out until it is all connected. If you have a big enough amp, you can certainly power two subs with it. Two amps ran from origianal amp is not a good idea anyways. It will soon be burned up.
Posted on Sep 09, 2009
8" compact subwoofer not working it was installed
post more information about your amp. its likely the vibrations moved something in the amps, or buttons.
Oct 10, 2013 | Alpine Swe-1000 8" Compact Subwoofer...
Hi Ive brought a Sony 2dx-gt590ui and sub and amp got it all wired up but the sub only works on radio can you tell me what Ive done wrong???
You can try to connect the remote power wire at amplifier to main power with a jumper wire if sub works with cd and other sources.Then check remote wire from behind radio or you can simply connect remote power wire to a another switched power source from fuse panel.Just make sure its a clean dedicated power source from fuse box and make sure it turns off amp..Goodluck
Sep 23, 2011 | Car Audio & Video
Hi i need some help i have a sub and amp in a ford fiesta 2001. ive chanced cd players to a ridspeed dv720. my sub was working fine with my old cd player but now ive put the ripspeed in it doesnt work. i...
You can use a "Y" cable to combine the two RCA cables to the one out. You will need a 1 male to 2 male cable. That will solve the signal problem. Is the amp functioning properly. I would check that first. Make sure your wiring is correct. Hope this helps
Aug 25, 2011 | Car Audio & Video
Subwoofer not getting max bass
try using a ohm meter and if its not making what the factory specs are its most likly it will keep loosing more and more power then stop working which is what ive had happen to me before
Mar 11, 2010 | Fusion RE-PK2120 900W Bass Pack: Amplifier...
My 10 in subwoofer in my srt 4 neon doesnt seem to work need help
do u have sound but no light?
I ran my neon straight from the power from the amp so soon as accessories comes on they light up!
Run neon wires positive to the amp directly p.con & negative to negative on ur sub outlet!
Mine had the same prob & it was trial & error & that set up works for me & a few mates have done the same!
May 01, 2009 | Kicker 01C8VR4 Car Subwoofer
Subs sound terrible (Ive tried so many things)
NO it won't be your battery. Sounds more like your deck.
Jan 22, 2009 | Jl Audio 12W3 Car Subwoofer
My amp was bad so i replaced it now my sub does not work i checked the wiring that goes from the amp to the speaker and everything seem to be ok then i put another speaker thinking it might be the sub and...
It doesn't sound like the wiring from amp to sub is your problem.
Is your amp getting a power light ?
Are you sure your remote wire is hooked up properly ?
Check both ends of your RCA cables
Jan 05, 2009 | JBL GT150 Car Subwoofer
Infinity ps-10 powers up but no boom
Try hooking up a different signal input to your powered sub, another stereo or even a dvd players audio output to the sub will work for a test. Just make sure the subs gain is down before starting. If it still not producing sound, the subwoofers amplifier is bad. I hope this helps.
Oct 10, 2008 | Infinity PS-10 Subwoofer
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Car Audio & Video Logo
12 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
