Question about Lexmark P450 InkJet Photo Printer
My Lexmark P450 printer turns on but won't get past the green bar. It just stops. What is wrong? I haven't used it in a while because it was out of ink, but I replaced the ink and I have tried plugging and unplugging it, but it just stops.
Hello, I have a Lexmark P450 photo printer that prints every picture in blue..... anything I can do?
You have tanks which are empty. Go into Printer Settings and go to the Maintenance tab, you should see details of which tanks are empty as well as Deep Cleaning and Ink Nozzle Pattern tests
Nov 22, 2016 | Lexmark Office Equipment & Supplies
Why won't my printer scan a document to my laptop?
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
Cd stuck in printer
You have a CD stuck in your printer? I won't inquire as to why there is a CD stuck in your printer because it is irrelevant.
Where in the printer is your CD stuck?
Aug 20, 2011 | Lexmark P450 InkJet Photo Printer
Just come to use my lexmark p450 my daughter bought me no user manual do they supply one
check the drivers CD - they usually provide the manual on it, If not, check with the Lexmark website.
Feb 07, 2010 | Lexmark Office Equipment & Supplies
Error code 1203
it is catridge error kindly replace the catridges.
Nov 24, 2009 | Lexmark P450 InkJet Photo Printer
Cartridge Error
you can contact Lexmark tech support direct, 1-800-539-6275
International Headquarters and
United States Headquarters
Lexmark International, Inc.
740 New Circle Road NW
Lexington, KY 40550
For Lexmark technical support call:
(800) 539-6275 Monday - Friday 9am - 9pm
Saturday Noon - 6pm
Sep 12, 2009 | Lexmark P450 InkJet Photo Printer
P450
Your cartridge did not fit the requirements of your printer.
Jun 06, 2009 | Lexmark P450 InkJet Photo Printer
Paper jam in lexmark p450
u have to change the roller of your printer your problem will solve
Sep 01, 2008 | Lexmark Office Equipment & Supplies
Lexmark, photo printer
Try to pass several sheets of plain paper
Then try the thicker photo paper.
If it is giving trouble send it back
Dec 31, 2007 | Lexmark P450 InkJet Photo Printer
Lexmark P450 InkJet Photo Printer Logo
65 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
