Question about HP IPAQ hx2790b Pocket PC
Describe and/or how to hardreset my iPAQ 2795
  • 178 Answers
Perform a Hard Reset by:
Pushing the Calendar, Messaging and Power buttons while pushing the stylus in the reset hole.
Please rate if helpful...
Posted on Sep 10, 2009
My hp ipaq 2795 has recently started having static when playing mp3 files with media player using both headphones and the internal speaker while play files that were previously static free . the unit also...
It is, most probably, behaving like that because some application is taking too much processing power, hence, consuming battery, which, by its turn, heats up. Besides, active data connections are known to drain the battery very fast. Anyway, Google for Dotfred's TaskMgr.exe, copy it to your device and run it You'll see which application is taking more power than others.
Just my 2 cents... Carlos
Apr 14, 2010 | HP iPAQ HX2795 Pocket PC
On IPAQ hx2700, how do I do a hard reset? I want
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
from the Reset button.
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
HP IPAQ pocket PC HX 2795 can not connect to wifi. I will pay for live chat if you could solve the problem
you need network code which can be WEP or WPA/WPA2 depends on how you set up your router.Also check manual what wifi is supported by your device.
Aug 15, 2009 | Cell Phones
Cannot send and receive sms, mic is muting
you can hardreset your PAD
i had tried and it's works
Feb 03, 2009 | HP iPAQ hw6515 Pocket PC
Ipaq H3630 how to do a hard reset
Compaq iPAQ h3630
Resetthe iPAQ H3000 and Clear Memory
Resetting the iPAQ
Ifyour iPAQ H3000 responds slowly, stops responding as expected, or“freezes,” try resetting it. A reset causes the iPAQ H3000 to restartand re-adjust memory allocation. Unsaved data in open windows may belost. Use the stylus to press and hold the Reset button for about twoseconds.
NOTE:Do not turn off your iPAQ as it must remain on in order to reset.
Clearing memory
Ifyou want to clear all data from your iPAQ H3000 and return it to thefactory settings, you should clear the memory.
Clearingmemory deletes all data and restores the iPAQ H3000 to its defaultsettings. Programs installed at the factory remain, while data you havecreated and programs you have installed are erased.
1.Using the stylus, slide open the On/Off door on the base of the iPAQH3000.
2.Slide the On /Off switch to the Off position using the stylus. Waitabout one minute, then slide the switch to the On position.
3. Close the Battery On/Off doorusing the stylus.
NOTE
:Use CF Backup/Restore or ActiveSync to keep a backup of your iPAQ dataso that if you need to clear memory, you can restore the data on youriPAQ.
http://www.hardreset.eu/compaq_ipaq_h3630_hard_reset_soft_reset_en.html
Aug 29, 2008 | Compaq iPAQ H3630 Pocket PC
IPAQ H4150
Is it under warranty?
If you have tryed the full reset / hardreset.
and still the device doesn't give out any signs of life, I suspect there is a fault in the mainboard how are the battery connections? all good?
theres a motherboard replacement service available
http://www.ipaqrepair.co.uk/view_product.php?product=1268
you can also buy the parts yourself and replace
http://www.ipaqrepair.co.uk/store.php?cat_id=19&catname='iPAQ%20Parts%204100%20Series'
But if you have warranty then send it in for warranty repairs.
Jul 13, 2008 | HP iPAQ H4150 Pocket PC
Ipaq
Do a hard reset - note it will remove all your data.
If a hardreset doesn't fix the problem then you either have a faulty touchscreen or other fault in it and you have to send it in for serivce contact HP.
Jun 28, 2008 | HP iPAQ RX1710 Pocket PC
Language
Do 1 think just do hardreset ur mobile then after start it it will ask for choose a language then u can select english language but remember after hardreset data will be lost or u can change it from start>program .. , for hardreset ur mobile u need to enter a pin into a small whole which locates near the cardle port .
Gizmo1
Sep 29, 2007 | HP iPAQ hw6515 Pocket PC
IPAQ 2795 freezes during boot up.
I had the same problem. Contacted HP customer service chat, and got the following answer that
solved the problem:
1. Remove the battery for 30 minutes.
2. Insert it again in the iPAQ.
3. Perform a clean reset on the iPAQ and at the same time charge the iPAQ.
To perform a clean reset please follow these steps:
Press and hold the Calendar button, the Power button, and the Messaging button.
While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ.
The problem can also be solved by getting a new battery, and performing the clean reset while charging (using the portable charger, not the cradle).
Nov 16, 2006 | HP iPAQ HX2795 Pocket PC
Hard reset does not wok in my ipaq H3955
The touchscreen may be broken, try hardreset again if it doesn't help contact your dealer or HP for possible repairs.
Sep 14, 2006 | Compaq iPAQ H3955 Pocket PC
HP IPAQ hx2790b Pocket PC Logo
168 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
