Question about Kettler Exercise & Fitness
Error 1 in kettler marathon tx3 treadmill - Kettler Exercise & Fitness
4 Suggested Answers
  • 3 Answers
SOURCE: Message in the display "err 2" and my kettler treadmill doesn't work
Hi Rendra,
Try this:
Switch the treadmill off and then on again.
Push the "minus" speed button and the "stop" button simultanuously.
If all is well you will now have entered the maintenance mode.
Next push the "plus" speed button and the "stop"button smultanuously.
Now you you've reached the error mode.
Push the "plus" or "minus" speed button to browse the error codes untill you've reached "L er".
The push start to erase the message.
Turn the power off and then on again to restart the treadmill.
With any luck the error has disappeared and the treadmill will function again. If not.....you'll have to contact Kettler.
Btw...This error occurs when the belt is "pushed" by the runner. For example when you put weight on the handlebar and the push your feet backwards.
Posted on Aug 30, 2009
anupam19
  • 263 Answers
SOURCE: The running belt on my kettler marathon tx1
Use grease and check if any lock is there
Posted on Mar 12, 2011
ercupa190
  • 12223 Answers
SOURCE: TX3 folding treadmill. switch on says ERR how to fix is the question>
This is probably a 1) faulty speed sensor or
2)the speed sensor is not plugged in properly.
3)Its also possibly a faulty motor control board or
4) lower board. T
he error codes will differ between makes and models but could be e1.
However if you send the complete information, if can not fix you treadmill, how model, mark, serial number, I can handle more specific.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Nov 18, 2011
My kettler tx1 marathon running machine causes the electricity to swith off in the house. This occurs when I start the treadmill, not when I simply switch it on. Any idea as to the cause?
The motor or the Motor control board is faulty. Can be the motor brush or the shorted igbt transistor in the motor contol board. If you wish to get some more details about treadmill repair then check the following link.
http://electro-medical.blogspot.com/
Sep 28, 2016 | Kettler TX1 Treadmill
The weight number not working?
1) open the keypads and clean for oxide, and dirty with the ribbon cable and tight the connector upper very well.2) replace battery if have, and clean the battery contacts very well3) adjust the REED swtich see the diagram attached.God bless youa5028f16-84a6-49c6-8f0b-c64dffc6bd6f.gif
Apr 04, 2013 | Kettler TX3 Folding Treadmill
4) lower board. T
sincerely.
E.CUADRA
Nov 16, 2011 | Kettler TX3 Folding Treadmill
ERR on the treadmill when I switch on. how do I fix and get working
Any other codes displayed? Safety key fit firmly in? Go to the front of the treadmill turn off the power switch off and unplugg the unit for at least 30 seconds then plug in the unit turn power switch back on. If this does not clear the error code your unit will most likely need to be serviced.
Error toronto
Please go to the website: https://www.kettlerusa.com/parts
you will see Firmware and USB Driver for repair Error.
Thank you in advance, sincerely.,
E.CUADRA
MANAGUA, NICARAGUA.
Oct 17, 2011 | Kettler TX3 Folding Treadmill
Kettler Treadmill TX 3 gives error 91 supplier told it was the Power supply print. We changed it including the motor and the problem was solved for a couple of weeks. Now it is back again? Please...
Problem with Trendmil TX-3 err-91 problem is solved ... speed sensor (photo transistro in photo cell is damaged).The palsis in colector is 5V Amplitud .
Apr 05, 2011 | Kettler TX3 Folding Treadmill
The +/- speed buttons and the red stop button do not function
Sounds like the function keypad has failed or worn out from excessive use of those buttons Call Kettler's customer support
KETTLER International Inc.
P.O. Box 2747
Virginia Beach, VA 23450 USA Tel (757)427-2400 Fax (757)427-0183 Email info@kettlerusa.com or www.kettler.co.uk
Jul 17, 2010 | Kettler TX1 Treadmill with FREE INSIDE...
Hi Rendra,
Try this:
May 10, 2009 | Exercise & Fitness
Exercise & Fitness Logo
462 people viewed this question
Top Kettler Exercise & Fitness Experts
ray gallant
Steven Brandon
Steven Brandon
todd
Are you a Kettler Exercise and Fitnes Expert? Answer questions, earn points and help others
