Question about HP LaserJet 1022nw Printer
This has been a problem since the SP3 update. Worked great until that. It will work on USB cable cut not wireless. I tried many suggestions form the web but so far nothing has helped. Can anyone help?
  • cybor462 Sep 09, 2009
    Printer will not print wireless since the SP3 Windows update. WIll print USB but not wifi. The router has the MAC address of the printer which worked before the SP3 Update but since it has to be hooked to a cable.
    President:
  • HP Master
  • 1,447 Answers
It is problem driver support
sp3 not support all hardware
Posted on Sep 09, 2009
  • Sazeed Computer
    Sazeed Computer Sep 11, 2009
    it is problem printer configure
Where do I get Windows XP(sp3) drivers for the LG-NORTEL ELO UAP3000N Wireless adpater that work, The one on the CD do not function correctly.
go to the web site for the wireless adaptor and find the download for that particular unit
win xp and win 7 are no longer supported and any cd wanting any update will not work so you will only get upgrades and drivers form the manufacturer web page
Nov 11, 2017 | LG Nortel Wireless N USB Network Adapter
MX 860 won't print. Had it working wirelessly and then connected it to the MAC by USB. Now won't print
Hello, Paige.
If your printer worked OK wirelessly, the only problems could be with your USB cable, USB port on your Mac, or the printer driver.
Move your cable to a different USB port and try again.
If still a problem, remove and reinstall the driver.
If still a problem, replace your USB cable.
Hope these suggestions help.
Jan 09, 2010 | Canon Office Equipment & Supplies
Garmin nuvi 255w trying to register and update maps. Got the Firefox addon-loaded successfully, restarted firefox; plugged in usb cable to pc and GPS; can not find my device. Tried XP sp3 desktop and vista...
The problem was following the Garmin instructions too closely. What I found via a GPS forum was that some USB cables can be finicky and trying different USB cables may solve the problem. In my case I found I had to turn the nuvi 255W on normally during registration; then connect the USB cable to device and PC. Then the registration and download worked.
The documentation is not clear on this.
Found I had the latest map; but did upgrade my firmware from 5.90 to 6.10.
Dec 29, 2009 | Garmin nuvi 255W GPS Receiver
Uninstalled SP3 to get mouse to work.
Right click on my computer, click properties, click on Automatic Updates and select Turn Off Automatic Updates.
Open Control Panel, open Security Center. Then click on Change the way Security Center alerts me, Uncheck all three check boxes.
And now see if your problem cures
Nov 25, 2008 | Microsoft Windows XP Professional With...
Computer cannot detect camera at all!
Can you use a USB card reader? The canon software is great but it best used for using a method called tethering your camera (when you shoot directly from camera to hard drive)
Jul 15, 2008 | Canon PowerShot G9 Digital Camera
USB / hardware problems, caused by MS updates!
Wakanska2003:
I typed quite a long response for you yesterday. Unfortunately, in my haste over another situation, I clicked off the page before it was posted. This will probably save you some time reading, anyway, as I will try to condense the same information I wrote yesterday. If you need additional detail in regard to the processes enumerated below, or how to accomplish same, please advise.
First, yes, SP3 has known and acknowledged issues, and many users have uninstalled the service pack until the bugs are worked out. Presuming the uninstall files have not been removed from your system, you should also be able to remove SP3. Uninstall the program by using Add/Remove Programs (Control Panel) - you should see SP3 listed toward the bottom of the program list.
Two other matters go hand in hand with this. In addition to the SP3 file itself, there have likely been numerous other updates which were reliant on SP3 for functionality. If you utilize the system restore function, and if there is still a restore point available prior to SP3 install, you should be able to completely revert your system. Otherwise, it will be a matter of isolating the updates that need to be removed (due to removal of SP3).
Secondly, I have voluminous experience with both service packs and automatic updates creating tremendous problems with my system. I spent months working with the "top level" MS R&D team in order to try to solve issues created by SP2 - MS finally closed the case with a status of unresolved. Further, my issues with Automatic Updates (A/U) started about 1.5 years ago, when MS changed the process and it consistently resulted in consumption of 100% of system resources, locking up the system continuously for extended periods of time. After MS put out a fix for this, I installed, and again enabled A/U. (However, please note that I always had A/U set to download and let me decide when to install. This too was due to prior negative experience of great magnitude.) Needless to say, the same issues occurred again within a matter of months, although every single "fix" of previous "fixes" MS put out for this matter was installed as it was issued.
To this day, I have not again enabled (and do not intend to) the A/U process. Rather, I visit the Updates site periodically and download appropriate updates, with my complete control and interim verification of the entire process. Therefore, though it is an extremely personal decision, my choice is to disable Automatic Updates. There are many, I am sure, who would suggest this should not be the approach; however, with the full months worth of time that have been eaten up because of the A/U process, I find it much more useful and helpful to control updates myself.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Jun 05, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Jvc gz-mg130 and jvc cu-vd20
I had this problem with the GZ-MG505AA (connecting to WinXP SP3). I tried a different USB cable and it worked first time.
Not sure what is different about the cables (the original cable worked fine with my WM 6 mobile phone).
Dec 27, 2007 | JVC Video Cameras
"a service installation section in this INF is invalid"
If the player is showing up in your Windows' Device Manager under "portable devices" with a yellow "!":
1.) Right-click the yellow "!" and choose "update driver".
2.) When given the option to connect to Windows Update, choose "no, not this time" and click next.
3.) Choose "Install from a specific location (advanced)" and click next.
4.) Choose "Don't search. I will choose the driver to install" and click next.
5.) Click the "Have Disk" button. Browse to C:\Windows\inf and choose the file marked "wpdmtp.inf"
I can't believe the generic players have such crappy support when so many people have this problem! I think the Windows file problem might be caused by "compressing old files" when you do a disk cleanup.
Oct 15, 2007 | RCA OPAL M4001 MP3 Player
HP LaserJet 1022nw Printer Logo
35 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
