The a.c blows very low volume like compressor
The a.c blows very low volume like compressor is on low could it be it is running on 110 not 220 ? fan motors is fine ,sometimes the full volume comes on but not often
  • jackcochran Sep 10, 2009
    well it is the capacitors and switch
  • 128 Answers
You check the setting on the remote if without remote check the selector switch,
Posted on Sep 09, 2009
Air compressor Don't work Blows hot air
Most likely you have a leak in the system. The low pressure switch will not allow the compressor to run if the pressure in the system is too low. Could be a faulty switch or low pressure in the system. If the compressor is running, but you get no cooling, you have a leak.
Aug 09, 2014 | Cars & Trucks
2004 sebring air conditioner stops and starts
Low freon will cause the compressor to short cycle, when the compressor runs the pressure in the low line is pulled down and the low pressure switch turns it off. Not running the pressure builds up and turns it back on. In the old days there was no low pressure switch, with no freon to carry the oil the compressor was destroyed.
Jun 28, 2014 | 2004 Chrysler Sebring
Is there any easy and cheap way to find out if the compressor is bad; it won't blow cold nor will it let us add any r14
I'm assuming you mean R134 if it is a 2000 model car.
Not sure what you are saying the problem is. The compressor has to run to add freon if it is low. Normally you jumper the low pressure switch to make it run while you add freon.
Is the compressor running ? And if so, what are the high and low gauge readings ?
Feb 03, 2013 | 2000 Mercury Sable
I have a 2001 Ford Mustang V6, the ac is blowing warm air. We checked the refrigerant and it is full. The ac compressor will kick on for a few seconds and then kick off. Why is the compressor not staying...
it's either low (in spite of your readings) or your a/c clutch is not working correctly or you have too big an air gap in the clutch.
First, just disconnect the 2 pin connector from the a/c pressure cycling swithc and jumper the 2 pins with a wire to force the clutch to stay engaged. See if it blows cold then, and stays engaged. You can run this way for about 15 minutes before you have to pull the plug.
report reulsts.
please don't forget to rate.
Sep 01, 2011 | 2001 Ford Mustang
My ssl5l compressor builds pressure real slow now. Rings or Valves? it did get a little warm while sandblasting lately....
Very rare to have problems with rings. Blow-by would produce high pulsating pressure in the crankcase causing oil to blow out the oil filler plug/ dipstick. If normal crank pressure, suspect problem with valves or gaskets. Remove air filter cover and check for air blowing out of intake or very hot head or air discharge tube. Leaking valves or blown gasket will cause low volume/ low pressure and hot discharge air. Remove the in-tank checkvalve and look for carbon deposits /debris build-up. If the checkvalve and the interior or discharge hose are coated with oil deposits /carbon, most likely problem is valve plate/ gaskets /head. Good luck with your repair.
May 03, 2011 | Ingersoll Rand SS5L5 Ir Electric...
1997 jetta ac works for one minute then warm air blows
check the refrigerant level. The compressor is running until the low pressure or high pressure switch switch cuts it off.
Running the unit without enough refrigerant will damage the compressor because the lubricating oil is dissolved in the refrigerant. This is the reason for the low pressure switch cut off--to protect the compressor from damage.
If pressure gets too high, the compressor seals will blow. Thus the reason for the high pressure switch. Too much refrigerant or too much air in the system (due to a leak) will cause high pressures.
If refrigerant level appears to be correct, then suspect trapped air from a leak causing a high pressure cut-off. If refrigerant is low, suspect a leak causing a low pressure cut-off.
Mar 02, 2011 | Volkswagen Jetta Cars & Trucks
My microphone volume of Nokia E71 is very low. Opposite end person can hear my voice at very low volume.
try cleaning your mouthpiece by blowing it with a compressor. should that fail contact a Nokia Agent to replace Microphone.
Nov 19, 2010 | Nokia E71 Smartphone
I can hear the air compressor come on but doesn't blow cold
If it is blowing air and the compressor is running you are low on freon more than likely. make sure the fan on the unit is also running it helps it get rid of heat on the external coils. if all fans are running and the compressor is running it is low on freon.
Aug 08, 2010 | Dometic Rooftop RV Air Conditioner
Compressor will not stay on.
very good possibility that it is low on freon. If indoor unit is blowing ambient air, not cooling is happening. If this is the case and you are sure the compressor is running and then shutting off, the compressor could be overheating and the internal overload is taking out the compressor. If outdoor fan runs and compressor runs, probably cause. If capacitor is bad, unit would most likely not run that long. While unit is running, feel the large line at the condensing unit. If it is cold, and stays cold, could be something else going on. If stays warm, most likely low on freon.
Apr 19, 2010 | Intertherm P3RA-030K Air Conditioner
My Ruud Achiever 90 Plus not blowing cooled air
Look on the condensor, (outdoor unit) at the very bottom of the rear panel and you should find a red reset button. push it. If that does not solve the problem, and the outdoor unit is running (make sure both the fan AND the compressor are running) then you are looking at a low refridgerant issue and possibly dirty coils.
In that case, clean the coils and have refridgerant added.
Sep 23, 2009 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
