Worked fine for a year - now the sound cuts out on a regular basis when playing itunes.
Try the following, it shuld fix the issue;
Open up Quicktime (if you cant find a .mov or .mpeg video file go to Program Files, Quicktime, QuickTimePlayer) go to Edit, Preferences>Quicktime Preferences and go to the audio tab, be sure to set everything as follows:
Rate: 192kHz
Channels:Set to be equal to the speaker setup you have Apply and then OK and close Quicktime and iTunes and then start up iTunes.
Regards,
Anirban Mazumdar
http://www.ikarmatech.com
Gasoline cut-off saws are a simple and extremely robust tool that will easily last for many years if treated with respect and maintained regularly .
During normal operation it is absolutely imperative that the correct fuel/oil mix is always used. An incorrect mixture leading to a lack of lubrication is by far the easiest way to ensure an untimely death for your cut-off saw.
Here's a list of regular cut-off saw maintenance tips that will keep your machine running and running:
