Washing machin cluch
How do i change the cluch on washing machins
  • 35 Answers
Remove front panel, remove spring clip holding clutch to motor shaft then pull clutch off shaft or gently pry off if stuck.
Posted on Sep 19, 2009
My whirlpool washing machine model 3SLSR6233MQ3 it would not spin but you can hear the sound of motor running, the drum & agitator are not rotating.
frist check lid switch make sure that ok then check spintude look for metal flake it see them might want replace the spin tude cluch
Mar 27, 2018 | Whirlpool Washing Machines
The cluch keeps slipping
Probably need a new belt. Get thee to a sewing machine shop.
Feb 15, 2015 | Brother Sewing Machines
There is a hole in the drum of the lgf1247td leaking water- is it repairable?
may be problem with the cluch assyble,,,if its making loude noice,,you have to change,it,,might water lealing from that..
Dec 31, 2013 | LG WM2277H Front Load Washer
The clutch in wf t1022tpx is proken and i buy anew one , but i cant open the hub fixing nut inside the machine how i open it
You should be able to access the cluch from the back and bottom of the machine. You may need an inpact gun to remove the nut. check to see if it is left handed nut. i believe it is.
Oct 20, 2012 | LG Washing Machines
Hotpoint VBSR3100GWW Top Load Washer. the washer spins, but very slowly. Is it the cluch? Can I fix it with the correct parts?
this machine does not have a clutch but you may want to pop the front off by inserting putty knife to release clips on the top of the front panel , there you can inspect the belt to see if it is worn
May 12, 2011 | Hotpoint Washing Machines
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Washer wont spin
It is your cluch on your motor. Your cluch what holds your transmission in place while spinning.
Nov 18, 2009 | Frigidaire FWS833A Top Load Washer
Whirlpool washer beltdrive won't spin how do i
If you over tighten the belt it will not spin.
Jun 14, 2009 | Whirlpool CAM2752KQ Top Load Washer
Washing machine drum won't turn when loaded
your gers in the cluch sistem are gon for good ,,sorry
Apr 05, 2009 | Fisher and Paykel (IWL12)
Washing Machines Logo
Top Washing Machines Experts
