Question about Singer 7442 Mechanical Sewing Machine
Not Stitching at all,, never had this problem before,, just replaced the needle... Tension seems fine, i have never used any other stitch. Singer Prelude..
  • Singer Master
  • 1,388 Answers
If you cannot form ANY stitch at all...
Check the timing of the needle to the hook. HERE is a guide to generic principles of Timing
Best Wishes Martyn
Bargain Box in Australia
Posted on Sep 10, 2009
Testimonial: "I had a feeling that was what it was,, i just replaced the needle. I will study the guides you gave me."
Needle stopped penetrating my fabric
you need to replace the needle again, is the needle the right one for the heavy fabric?
Dec 10, 2014 | Sewing Machines
Singer 8770 beeps twice then stops stitching
do you have a manual?
try a new needle
adjust the top tension
try rethreading the machine top & bobbin
May 16, 2012 | Singer Curvy 8770 Electronic Sewing...
How do you stop stitches bunching up on a Singer Symphonie?
try changing the needle
also try changing the top tension
clean under the needle plate & in the bobbin area for lint or loose threads
Apr 21, 2012 | Singer Sewing Machines
Singer melodie 20 is not stitching
have you tried to adjust the top tension?
is it the right needle for the machine?
it's very possible that the machine is out of time
Mar 29, 2012 | Singer Sewing Machines
I have a Singer 367 and it will not do a zigzag stitch. The needle goes from side to side but I end up with 4/5 straight stitches and then 2 zigzags then back to 4/5 straight stitches. The tension and...
Either you have a blunt or bent needle or the needle is in the wrong way round or failing that you may need to retime the machine which is quite likely, if you email me I can attach instructions kendourof@yahoo.com
Aug 30, 2011 | Singer Sewing Machines
Tension problems
Hi, check that the thread tension knob makes only one rotation from 0 to 9 and stops at each ends, see that it moves in and out as you increase or decrease the tention, see that the small tension wire to the left of the knob is still in place, in any of these fail you need to replace/repair that assembly.
Aug 11, 2009 | Singer 7462 Mechanical Sewing Machine
Looping of stitching on the reverse of the material.
put the tension to about 4 and make sure it is threaded in a N shape and remember the thread catcher above the needle from the bobbin to left down round tension up to arm down the side.
Mar 26, 2009 | Singer 1725
I have an Aldi Delta NM902-05 sewing machine which was stitching OK yesterday. Todya if it skipping a few stiches on the top sticth. My mum is the sewing whizz and she reckons it's the tension, however,...
sarah if the top tension is to tight it might slip stitches but as always when there is a problem with stitching you should change the needle and make sure it is in right.
Taking the needle plate of and cleaning with a fine brush around the bobbin and feeders will help and should be done regular.
Aug 19, 2008 | Singer 7462 Mechanical Sewing Machine
Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Jun 27, 2008 | Juki TL-98Q
Singer 7442 Mechanical Sewing Machine Logo
246 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
