Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven does not heat over 100 degrees
Stove top works but oven does not heat up past 100 degrees. for a ge profile stove
    Brigadier General:
  • 3,513 Answers
Hi
It sounds you need a new control panel circuit board.
hope you will be helpfull
Thanks for contacting Fixya.com
Posted on Sep 09, 2009
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
It turns on but won't heat past 100 degrees.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Sep 26, 2010 | GE Profile JS968 Electric Kitchen Range
No Bake; everything else works
Hi, When you put the oven on bake, can you see the ignitor glowing but get no flame?
Sound like the ignitor might be getting weak and not opening the gas valve. Please let me know if this sounds like the problem.
It is common for the ignitor to go bad. Even if it glows, it can be bad.
Please let me know if I can assist you further.
Vic
May 31, 2009 | GE Profile JGS968 Gas Kitchen Range
GE profile gas range
Hi threeamigoma,
ngafm at your service,
Your stove top and broiler works well. But the temperature won't go past 100. There is a little sign below the 100 saying ON. First time I have ever seen this.
More than likely the thermostat is faulty. But you can not tell exactly with out hands on diagnoses.
Since I am unable to be there, you will more than likely need to call a tech to service this.
There are a few things that need to b tested to narrow down the precise parts needed.
Bless You ngafm.
Please rate me before you sign off the site.
Thank You
Sep 11, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44 stove
Most likely the oven ignitor is bad or weak.  You can look at it and see how it compares to the broil ignitor.  If you see a whitish color on the ignitor and if it doesn't fully glow then it needs to be replaced.
Oct 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't heat
This could be the ignitor. The ignitor is located under the bottom of your oven. you get to it from the inside of the oven. A quick check though is to set the oven to bake and wait about 30 seconds and see if you can see a faint orange glow from the bottom inside of the oven. If you do then your ignitor is probably working ok and the problem lies somewhere else.
Apr 25, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
859 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
