Display Box blinking blue display box on monitor
    Scholar:
  • 85 Answers
Could be 3 things
1. your data cable from your monitor to your computer is not plugged in
2. your monitor its not plugged into the right place on your computer.
3. your computer has and issue or is not turned on. easy way to check this it to plug the monitor into another computer.
Posted on Sep 09, 2009
How do I remove the blue box in the middle of screen on the asus VS208NR
Unplug the power from the monitor, wait for 10 seconds, plug back in. Worked on my ASUS Monitor
Aug 03, 2012 | ASUS LCD Monitor
How to fix no signal from monitor to desk top ?
Plug in the monitor cable (blue head) to computer display car properly. If you find difficulty in getting display card, it is located at back side of Cabinate box (CPU Box) and try to match the pin orientation.
Aug 29, 2010 | Computers & Internet
A blue box on desktop appears, says 'Out of Range'
Try connecting a different monitor and if the issue does not persist then the other monitor/display is already defective. As per the description that is provided, the problem is with your Display/Monitor.
Aug 15, 2010 | Dell Computers & Internet
Has a blue dialog box that says out of range
Hello
It sounds like you have two separate problems.
The first one is the "out of range" issue. This means you are trying to display a screen resolution that is too high or too low and your monitor cannot display any image. Reboot your computer with another monitor or into safe boot mode and change the resolution to an industry standard (800x600 / 1024x786) and then see if your monitor will display the image. Once you can see the image on your monitor, you can make adjustments and it will automatically revert back if you cannot see the new display settings.
Update your video graphics card drivers to get the best possible resolution.
As for the buttons on the front of the monitor not working, this may be caused by the "out of range" issue above. It could also indicate that your monitor may be going bad. Try the above steps - if you get no image from the monitor, try moving the monitor to another known good computer and see if the button functionality works after it displays an image.
May 04, 2010 | AOC 193FW LCD Monitor
So I hooked this moniter up to my hp and all I get is two blinking lights
One monitor serves as the primary monitor, and this monitor displays the Logon dialog box when you start your computer. In addition, most programs will display windows on the primary monitor when you initially open them. You can select different screen resolutions and different color quality settings for each monitor. Multiple monitors can be connected to individual video adapters or to a single video adapter that supports multiple outputs. To configure the arrangement of multiple monitors:
  1. Click Start, and then click Control Panel.
  2. Click Appearance and Themes, and then click Display.
  3. On the Settings tab, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  4. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
NOTE: The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Change Primary Monitor
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to designate as the primary monitor.
  2. Click to select the Use this device as the primary monitor check box. Note that this check box is unavailable when you select the monitor icon that is currently set as your primary monitor.
View Same Desktop in Multiple Monitors
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to use in addition to your primary monitor.
  2. Click to select the Extend my Windows desktop onto this monitor check box. After you enable this feature, you can drag items across your screen onto alternate monitors. Or, you can resize a window to stretch it across more than one monitor.
Move Items Between Monitors
  1. On the Settings tab of the Display Properties dialog box, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  2. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply.
  3. Drag an item on your desktop across your screen until it appears on the alternate monitor. Or, you can resize a window to stretch it across more than one monitor.
Using DualviewOn many portable computers and some desktop computers (those with two video ports on one video card), you can expand your display to a second monitor by using Dualview. Dualview is very similar to the multiple monitor feature, with the exception that you cannot select the primary display. On a portable computer, the primary monitor is always the LCD display screen. On a desktop computer, it is the monitor that is attached to the first video out port. Once you attach the second monitor and turn on your computer, use the Display tool in Control Panel to configure your settings, just as you do with multiple monitors. You can use Dualview with docked or undocked portable computers.
Mar 08, 2010 | HP A4331D 20" CRT Monitor
I came back to the computer and the screen was blue with nothing on it. I finally turned the monitor off and then back on. A quick box appeaers saying imput:analog, disappears, and then the monitor remains...
OS system corrupted & display driver lost. 1st try to install display driver hope you see the good result. if not then you need to format the OS and installed it again.
Jan 30, 2010 | HP Vs17 17" LCD Flat Panel Monitor
Message blinking at the centre of monitor
OSD Unlock : Press and hold the [1] and [▼] buttons again for 5 seconds. The message “OSD UNLOCK” will then display briefly, indicating that the OSD image settings are now unlocked.
You will find that and other information in the manual located here. The above information is found on page 7.
Hope this helps. Please remember to rate this information.
Thanks
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
Cannot get the resolution right
on your desktop right click and choose personalize then display settings and change the resolution to 1440 * 900
Nov 30, 2008 | Niko 1920W Monitor
No Display on connecting Data cable of PC
The Monitor is bad, with the CRT Monitors you cannot just replace the connections, because it is embedded into the CRT. So it is probably something that lies with in the monitor itself. Try to connect another monitor to the device. See what the result is, my best guest is the CRT Monitor when bad. Time to replace! Sorry!
Nov 23, 2007 | Samsung 793S 17" CRT Monitor
"OSD lock" in blue box
The monitor will have the on screen display setting as locked, look at the monitor settins buttons, where you set the brightness etc.
Feb 14, 2007 | ViewSonic A71F (Black, Silver) 17 in.CRT...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
