Question about Whirlpool DU1055XTSQ Built-in Dishwasher
Odd perhaps burning smell
Last evening during second half of cycle an odd smell became present. No smoke but the prevailing smell. Finished cycle and removed dishes that were perfectly cleaned. Visually inspected interior but saw nothing out of the norm except the smell was there. This morning looked inside again and smell was faintly still present after leaving it partially opened throughout the night. Is it safe to run again this evening? Is it covered under warranty (03/21/07 purchase date)? Cannot afford major repairs unemployed. Please advise. Your reply appreciated. Mario
  • 1314 Answers
SOURCE: soap door doesn't open
remove the door panel and replace the wax motor on the dispencer
Posted on May 22, 2008
SOURCE: Clean light flashes constanly. Won't clear out to start new cycle
This may help: http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Posted on Nov 15, 2008
SOURCE: Whirlpool dishwasher stopped working.
the t-stat under the diswasher is defect or the thermal fuse is defect its located on the main control. remove the inner door panel to get to it, check for contenuity for both items.
nbcrca:)
Posted on Apr 11, 2009
SOURCE: dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Posted on Jun 10, 2009
  • 4 Answers
SOURCE: A burning smell and steamy smoke come out when we open the door.
Normally, the last part of any cycle involves using the heater element inside, and at the bottom of, the dishwasher to give dishes a final hot rinse. Possibly some small plastic-type material has become melted and stuck to the element - which will remain hot even after all water is discharged. Hence the smell.
Posted on Nov 17, 2009
How to restart brush head after clog. See details.
Check the belt that drives the brush head, you most likely burned it up and you need to replace it.
Dec 27, 2016 | Vacuums
I set my brand new GE oven to bake and it almost immediately started to smoke. It continued to smoke even after I turned it off. It smelled like burning wood. It kept smoking (15 minutes) until I unplugged...
Wherever you bought it from should have a warranty. Get them out there to look at it. The smell of burning wood is odd. Check to make sure all of the packing material was removed prior to installation. That could be burning cardboard on the outer casing of the oven.
Dec 18, 2014 | Ovens
Knocking engine
Seized engine due to no oil I expect.
Jun 07, 2017 | Ford Explorer Cars & Trucks
Odd smell from engine
If you have been (revving the car/racing/accident/excessive speeding) you will smell something similar to burning oil from the engine, also if it has been more than 10,000kms (6000 mile) since last oil change you should get it serviced.
Dec 26, 2013 | 2005 Mercury Mariner
White smoke and odd smell from tailpipe
maybe a rodent crawled in and it got way up into it and is stuck and it will be a while till it gets burned out? no clue. see a mechanis
Sep 07, 2012 | 1999 Dodge Intrepid
Hi my candy washer/dryer keeps making a odd noise when quick spinning. Lastnite there was a 'odd smell like burning rubber. when i opened it there was a little smoke, and a bit of rubber inside. is it...
You have a mis-aligned drum and you should check the perimeter rubber gasket to verify if there is some rubbing on it. I can't say for sure what the odd noise is except for a rubbing situation. If you ar able to replace the rubber then replace it and I hope you have been removing and cleaning you gasket to prevent any mildew build up. I would replace the washing machine if the motor and transmission is not operating. Good Luck
Jan 09, 2011 | Candy CNW156 Front Load Washer / Dryer
Top Load making noise. Wash cycle finished, open
bad lid switch.coupling broke and rubber burning or trans locked up
Nov 15, 2009 | Refrigerators
Dryer makes a high pitch squeal and when you open the door it has a burnt smell.
roller/supports bad or idler pully sticking or drum ball support depending on model the burn smell odd can be caused by dragging during operation
Aug 20, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool DU1055XTSQ Built-in Dishwasher Logo
73 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
