Question about Technics SA-DX930 Receiver
My technics sa-dx930 receiver stops working and an error message is displayed that says "overload" when i use the "b" speakers for my patio. This is a new problem. i have had the same outside speakers, wires and connections for about 9yrs without any problems. Anybody have a similar problem and or a solution. thank you
Hey, I own one of these systems. Whenever I touch two of the wires together (shorting it out) the system shuts down and overload appears on the display. My suggestion is too check your wiring (especially in the spliced areas) or replace the wiring to the outside speakers and try it again. If you dont want to try that, take the wires you have hooked to the A speakers and see if they will work on the B setting (a quick troubleshooting technique). Please let me know if it worked for you. Good Luck!
Posted on Sep 17, 2009
Connecting sub speaker to technics sa dx930
Yes, if it only has speaker-level inputs it would require an amplifier to properly drive it. Name the sub and maybe we can answer the second question.
Mar 28, 2010 | Technics SA-DX930 Receiver
My Technics AV Control Receiver SA AX530 is in overload
An amplifier should never be turn on without speakers, it will overload internally.
make sure speakers work and try again.
Dec 04, 2009 | Technics SA-AX530 Receiver
Technics SA-DX930 Sound cutting in and out
try rehooking up speaker wires. make sure no bare wire is showing and positive and negative are aligned correctly
May 19, 2009 | Technics SA-DX930 Receiver
Technics SA-DX930. I ran digital optical cable from the TV to the receiver using the tv/dss mode. It worked well for 4 months. It stopped working. I can get sound out of the receiver and speakers using...
If the only thing not working is the optical input, it is possible that the optical converter is defective. Without seeing the actual unit and testing the IC, I can't say for sure. If you have test equipment, let me know and we will attempt to track this down.
Dan
Mar 03, 2009 | Technics SA-DX930 Receiver
Overload on Technics SA-AX710 Receiver
u can measure the speakers impedance, if is ok. I think this can be a problem, when is speakers with 4ohm conected.
Dec 21, 2008 | Audio Players & Recorders
Technics SA-GX470
over load means your speakers and its cable----please check it for bad cable or bad speaker------try to insert speaker one by one and test each time to investigate the bad one.--------if every thing is ok and you keep good ventilation around your receiver (no blocking of ventilation holes)and you still have a problem your protection circuit in your receiver needs to be checked by service technician
Aug 06, 2008 | Audio Players & Recorders
Receiver overload problem
The overload message is indicating that a problem was found and the system is shutting down the output section to prevent further damage. There are probably poor connections on the main board and failing capacitors in the front end. Expect a parts vcost in the $10 range. Add in the local labor rate for the total repair bill.
Dan
May 23, 2008 | Technics SA-DX930 Receiver
Remote control
I have heard the phillips makes one... Philips Pronto TS-1000
Dec 01, 2007 | Technics SA-DX930 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
Technics SA-DX930 Receiver Logo
676 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
