HP Color LaserJet 2605dtn won't recognise Powerpoint anymore
My HP Color LaserJet 2605dtn won't recognise Powerpoint or Word docs & changes size of doc (eg 900 Kb powerpoint becomes 10Mb!). Any ideas?
Hp color laserjet 2605dtn driver windows 7 32bit
** Fixed **
I got my problem solved by followed below article steps.
http://printer-driver-download.us/hp-color-laserjet-2605dn-driver-download/
Thanks
Oct 04, 2012 | HP LaserJet 2605DTN Color Printer
My dad just got an HP computer with windows 7 and 64 bit. His HP Color LaserJet 2605dn is working except in Photoshop CS 4. It says he needs to install a printer. Any ideas?
If the printer is working fine for all applications except Photoshop, it isn't a printer problem. Does that version of Photoshop support 64 bit processing?
In any event you should call Adobe and run it by them.
Jan 23, 2011 | HP LaserJet 2605DTN Color Printer
Does not print in color
hi
thank you for using Fixya
go to folowing link to get all PDF doc for technicale support for your Printer
http://www.partshere.com/models/q7823a/CLJ2605_printer_basics.pdf
May 15, 2010 | HP LaserJet 2605DTN Color Printer
When printing large powerpoint presentations half way through it will give a pcl xl error missingdata readimage
too much data or not enough memory in your printer to support the job.
Also possibly corrupted data in your powerpoint doc.
if you are using PCL version of the driver, download and setup the PS (PostScript) driver from HP.
There are conflicts with printing PDF/Powerpoint docs using PCL driver.
let us know if this helps. Another thing you can try if possible, convert the Powerpoint into a PDF file and then try printing, but select "Print as Image" in the Advanced section of the print options.
Feb 03, 2010 | HP Color LaserJet 4600n Printer
How do I print double-sided automatically? HP Color LaserJet 2605
Go into the control panel, select the printer, select printing preferences, select finishing, put a checkmark in box where it says "print both sides"
Oct 09, 2009 | HP LaserJet 2605DTN Color Printer
Hp Color Laserjet 2605 dtn
Should be under warranty, call hp and get them to replace it
Oct 16, 2008 | HP LaserJet 2605DTN Color Printer
73 people viewed this question
jasbo
jasbo
