Question about Samsung UpStage SPH-m620 Cellular Phone
Screen and key pad continually blinking
When turning the phone on the screen and key pad just keeps blinking samsung
My samsung sgh 1997 will not turn on. just a grey battery blinking
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 24, 2012 | Samsung Infuse 4G ATT Unlocked SGH-1997 3G...
Stop key pad bleep
You can remove the battery and keep aside for sometime , then reset and open TONES> scroll for KEYPAD TONE > set the tone level to OFF.
Jun 27, 2012 | Samsung Cell Phones
I want to change the language setting to English
Hello thanks for using fixya
To change the language, Follow the given instructions:
  • Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  • Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
  • Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
  • Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
  • Scroll to the language Select English and press the "OK" button.
  • Highlight the "Input language" field and press the "Change" soft key. Scroll to the language to English and press the "OK" button.
  • Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
You have done itFor further help regarding Samsung S3650 Corby Download its User Guide. It will help you alot
To download User Guide Click Here
Downloading will start after clicking on it
Guide is in pdf format if you have no Adobe Reader software which support pdf files then Download it from here Adobe Reader
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
Feb 22, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I would convert an french my samsung e250
Follow this steps,
1. Press the "Menu" button, or select the "Menu" option, on your Samsung phone. Your phone menu will now appear.
  1. 2.Scroll through the menu using the directional pad and highlight the "Settings" option. Press the button in the center of the directional pad to continue.
    3. Scroll to the "Phone" option and press the middle button. Then scroll to the "Language" option and press the middle button. The phone will now show two fields: "Screen text" and "Input language."
    4. Scroll to the "Screen text" field and press the soft key under the word "Change." A list of the available languages will now appear in a drop-down box. On Samsung phones that use a SIM card, an available option is called "Automatic," which will default the phone to the language of the SIM card.
    5. Scroll to the language you want and press the "OK" button.
    6. Highlight the "Input language" field and press the "Change" soft key. Scroll to the language you want and press the "OK" button.
    7.Press the soft key under the word "Save" to save your changes and return to the phone settings menu.
Nov 23, 2010 | Samsung SGHE250i Cell Phone
Hi can you tell me how to turn the sound of off the key pad on a tocco phone
when you are on the main screen, push the lower button on the left side. If you push it, you will see a little speaker on the display. If you keep pressing the button until the volume reach 0, you sound of the keys is off :)
Jun 07, 2010 | Samsung Tocco Ultra Cell Phone
White screen on my samsung rant
There is a fix. Ok so what you wanna do is power off your Samsung rant then you take out the battery and put it back in. After that you open to the slide pad and hold down the T and Y keys then power it on while still holding the 2 keys after the Samsung logo pops up then you can let go. Keep the slide keys open while it is powering on. You can close the slide pad when your screen shows up then it should be fixed. Well hope this works for you it worked for my moms phone when she was having this problem. Note: If your phone screen freezes or turns white again just redo the process.
Jun 03, 2009 | Samsung Rant Cell Phone
I have a Samsung U900 and cannot turn off the key sounds without
to solve this at the main screen press volume down and u will get a pop up saying key tone volume keep pressing unil it reaches 0 and there will be no key pad sound but music etc will still work fine
Dec 07, 2008 | Samsung U900 Soul Cellular Phone
My key pad doesn't seem to work anymore! when I turn the phone on when it's open, the screen displays - DOWNLOAD in a red box. IF the phone is slid down before I turn it on, I can get to my password screen...
i had this same problem with my samsung e370 but yeah you have to take apart the phone and clean out dust and water quite easy reply with wat phone you have and can u take it apart...
May 31, 2008 | Samsung Cell Phones
V3i Problems
you need to have the flex cable replaced
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Samsung UpStage SPH-m620 Cellular Phone Logo
171 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
