Question about Car Audio & Video
How to how do u hook up a pioneer cd player
  • 601 Answers
Please follow the following instructions 1)Use a wiring harness equipped with an adapter plug for faster connection and installation.Disconnect the car battery while installing electronic equipment.
2) Make a note of the wire colors and connect the power supply wires to the DEH-45DH as follows:
Orange wire to the constant 12Volt
Yellow wire to the switched 12Volt
Black: ground wire
3) Connect these wires to control display functions on the DEH-45DH:
Attach the gray wire to the wire marked control panel illumination.
The brown wire connects to the dimmer.
4) Make the front speakers connections following this color scheme:
Left front positive (+) tan wire
Left front negative(-) Gray
The light green wire connects to the positive (+) terminal of the right front speaker.
Connect the dark green wire to the negative (-) terminal of the right front speaker.
5) Make these rear speaker connections:
Brown wire to the left rear positive (+) terminal
Yellow wire to the left rear negative (-) terminal
The dark blue wire attaches to the right rear positive (+) terminal
The light blue wire connects to the right rear negative (-) terminal
Hope this helps
Thanks
Smith.
Posted on Sep 10, 2009
My 1998 land rover discovery i replaced the stock cd player with a pionner after market cd player everything is hooked up properly but cant get sound
Oh... Pioneer may be bad. I had a new tape player that was broken the day I bought it. Pioneer did replace it.
Apr 28, 2013 | Cars & Trucks
This is not a car dvd/cd changer. it is a pioneer f727 301 disc changer. I took all of the dvds out and reinstalled them, still no sound.
Check Your Wiring Harness On Back Of Player Also Your Stereo Sometimes Pioneer Tends To Get Loose Inside The Wire Harness plug.
Mar 17, 2012 | Pioneer DV-F727 DVD Player
I have a pioneer djm mixer 400,I hooked it up to 2cdj mk1002. I want to run them through my pioneer reciever.which is a vsx 1020.im having a problem.IT works okay,if i run the cd player directly to cd...
If your CD player works hooked up to the DJ board, then try hooking the line out of the board into a auxiliary in or line in in or record in on your receiver using the appropriate cables.Try the CD in first and if there is too much signal then use the CD/Tape in. You need to match the output signal of your board to the input signal of your amp. Hope this helps.
Oct 22, 2010 | Pioneer DJm 400 Professional DJ Mixer
Wiring diagram for power input
What power input are you hooking it to? Do you mean how to wire it? Or hooking up amplifier?
If you want a user manual and installation manual, you can get them here:
http://www.generalmanual.com/Players/Pioneer-DEH-P2900MP-In-Dash-CD-MP3-WMA-Receiver.htm
Jan 25, 2010 | Pioneer DEH-P2900MP CD Receiver...
How to make mp3 work on DEH P3500 ?
when it says mp3 it means you can hook an mp3 player to the stereo and play music that way. if you have an mp3 player you need a cable that will hook the mp3 player to the stereo and you can get that cable from pioneer.
Nov 16, 2008 | Pioneer DEH-P3500 CD Player
How to hook up mp3
cant open the manual off pioneer.com i wanted to hook my ipod up does anyone know what the aux port is? for a pioneer deh-3500
Apr 22, 2008 | Pioneer DEH-P3500 CD Player
Pioneer Deh-p44 cd player- AUx input?
ya http://www.amazon.com/PIE-PIO-P-RCA-Pioneer-Adapter/dp/B000P9SLCA
Mar 05, 2008 | Pioneer DEH-P44 CD Player
Aux inputs
chek your wiring and your speaker.nad of coars the sound output of your dvd
Feb 01, 2008 | Pioneer DEH-P2900MP CD Receiver...
Pioneer deh-p2000 cd player
Sue,
I checked the Pioneer Database and your device is no longer supported.
But I have installed several Pioneer products over the years and they a re pretty consistent in their wiring patterns.
There is a Yellow wire on the harness that is much larger diameter than the rest. This is the one that needs to be connected to a constant +12 volt source to alleviate your problems.
Best of Luck.
Oct 30, 2007 | Pioneer DEH-P2000 CD Player
Car Audio & Video Logo
141 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
