Question about Abit GD8 Motherboard
GD8 motherboard I have the GD8 motherboard with a Pentium IV processor. I also have a AMD Athlon 1800+, i have been advised that this processor is better than the P IV. Could you please advise if i can safely swap the original P IV for my AMD Athlon without causing any problems to the workings of the GD8 motherboard, and could you please confirm that the AMD is the better processor. Any help you can give me will be gratefully received. Mark
  • 28 Answers
The Abit GD8 motherboard supports the Intel P4 and Intel Celeron D processors up to 800MHz front side bus. AMD Processors are physically incompatible with boards designed for Intel processors.
You should be able to upgrade to an Intel P4 or Celeron up to 2.0GHz, but you wont be able to put the Athlon 1800+ in the system.
Without knowing the speed of your P4, I cannot provide any benchmark or comparison details to the AMD 1800+.
Posted on Sep 09, 2009
    Brigadier General:
  • 4,044 Answers
The bad news is the AMD processor will not work on that motherboard according to the specifications listed here: www4.dealtime.com/xPF-Abit-MB-ABIT-GD8-INTEL-915P-ATX-RETAIL
I believe the AMD is just as good as the Intel Pentium but that is certainly a personal preference.
    President:
  • 1,653 Answers
The GD8 mobo spec says that the bopard is only compatible with P4 and Celeron D processors so no you cant swap it! Generally the Athlon 1800+ is a better processor but it depends on the mobo, BIOS, RAM setup etc.
My athalon xp2000 processor died. What can I replace it with that is compatible with k7s5a motherboard?
There are several versions of the K78S5A. The following answer applies only to v.3.x.
CPU: AMD Duron 200Mhz FSB CPU - 950 AMD Duron 266Mhz FSB CPU - 1800
AMD Morgan 200Mhz FSB CPU - 1.3G
AMD Athlon 200Mhz FSB CPU - 1.4G AMD Athlon 266Mhz FSB CPU - 1.4G
AMD Palomino 266Mhz FSB CPU - 1.2G
AMD Athlon XP (0.18u) 266Mhz FSB CPU - 2100+ AMD Athlon XP (0.13u) 266Mhz FSB CPU - 2600+
I hope that helps! Good luck.
GaugeMan
Mar 06, 2011 | EliteGroup K7S5A Pro Motherboard
AMD Athlon XP 2200+ vs amd athlon xp socket a 1350+ 1.35ghz
AXDA2200DUV3C is the part number. Do you need anything else?
Jan 02, 2010 | EPoX EP-8KRA2+ Motherboard
What is the best procesors(powerfull) for motherboard NF 61S MICRO AM2 SE..?
AMD Athlon™ X2 Dual-Core Processor
AMD Athlon™ 64 X2 Dual-Core Processor
are the best processors for this motherboard
Nov 28, 2009 | Biostar NF61S MICRO AM2 SE...
What are the motherboards compatible for AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2 2x512kb Fsb1000 Pib
hey i cant post a message on ere, can u help , once iv typed codes in iv pressed ok n it just flashes ok n store
Oct 06, 2009 | AMD Athlon 64 X2 5600+ 2.9 Ghz Skt Am2...
Motherboard cpu
The motherboard you listed supports AMD processors, (AMD Athlon XP/ Thoroughbred/Barton)not Pentium.
Jul 13, 2009 | ASUS A7V400-MX Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
Intel Pentium Dual Core and AMD Athlon 64 X2 processors
I'd advise don't start thinking below E2180. As per the performance go, E2180 and AMD Athlon 64 X2 5000+ are almost same but E2180 runs cooler. If you are going to use dedicated graphics card, go for E2180 and if you want a CPU for Integrated Graphics go for AMD Athlon 64 X2 5000+ because most of the 780G/790X chip-based AMD-compatible boards offer superior IGP.
Best wishes...
Nov 04, 2008 | Computers & Internet
Intel Pentium Dual Core Vs AMD Athlon 64 X2
amd is better for online gaming and grafix, from my personal view they also can take more power,than a standard dual core intel proccessor so id advise you to go for Amd if its for online gaming
E2180 Vs Athlon 64 X2 5000+
depends on what you plan to do with the cpu amd are good but a 3200 may only run @ 1.8 to 3.2 ghz depending while a intel 3200 will run 3.2 ghz.
I believe intel are more stable & run cooler than AMD but AMD benchmarks on Games better but run hotter (so get a good cooling fan & heatsink both pentium / celeron d & intel dou / dual core / core 2 dou and amd x2 have 2 cores (but watch your front side bus and cache the higher the better but the more $ also) then You need a good stable mobo that supports the chip you get (I preffer asus & msi for Gamers and biostar / msi for home users)
Sep 18, 2008 | AMD Athlon 64 X2 4600+, 2.4 GHz...
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Abit GD8 Motherboard Logo
156 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
