BLUE HAZE OVER MY SONY TV SCREEN...SOMETIME IS THERE WHEN I TURN ON TV.......OTHER TIMES IT JUST 'HAPPENS' WHILE I'M WATCHING TV......SOMETIMES I CAN FIX IT BY CHANGING CHANNELS..AND THEN GO BACK TO THE CHANNEL I WAS WATCHING....OTHER TIMES, I HAVE TO UNPLUG TV ...WAIT...RE-PLUG (REBOOT).........IT'S NOW HAPPENING ABOUT TWICE A DAY..........MANY THANKS FOR YOUR HELP.......IS IT A 'LIGHT ENGINE' PROBLEM? TV BULB PROBLEM?
This is not a light engine problem as stated above. It is an expensive repair. $650 to $1000 for the part depending on the model of your TV plus $300 for labor. The problem with blue haze is well known on all Sony LCD TV's made after 2003. The part that is defective is called the "Optical Block". I have the same problem on my TV that started yesterday. Here's the link to repair it yourself. Best advice, junk the TV and buy another. Not worth doing a $1200 repair on a unit that costs the same as a brand new one these days.
http://sites.google.com/site/sonylcdrptvproblems/sonykdf-55wf655opticalblockreplacement
Hope this helps. Remember, this repair is time consuming and complex. Good Luck.
Posted on Sep 14, 2009
  • 8,457 Answers
U fix the convergence prob. for this tv before?This tv is a DLP right? Ur light engine need adjusting.
Posted on Sep 09, 2009
Blue haze/blob near the center and lower right corner.
Failing optical block. check this website
Mar 08, 2010 | Sony KDF-E50A10 TV
Permanent blue haze on screen; looks like
The fact that you continue to have sound while the picture disappears points to one of three potential issues.
Issue 1: the LCD Panel.
Issue 2: The Inverter Power Boards (though these tend to cause power/shutdown/no video at startup than video distortion)
Issue 3: the Time Control Board - a small board at the top of the LCD panel on the back that relays data to the rest of the screen.
Any one of these three repairs, you should call Sony if the unit is outside of manufacturer's warranty. They are expensive to perform, and the parts are not cheap. Hopefully you have an extended warranty to help with the issue.
Jan 24, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Near the bottom edge of the screen on my Wega KF-50WE 610 has appeared a ''blue haze'' that appears after the TV has warmed up. It started a few days ago as ''fuzzy blue dots'' about the size of silver...
This was caused by a defect in the optical block of the TV. It will only get worse with time and the only way to fix it is to replace the whole optical block which is very expensive (over $1000 usually) and time consuming (you need to take the whole TV apart). However, since it was a defect, there was a class action lawsuit that caused Sony to extended the warranties for certain models on the optical block for parts and labor. Call Sony to see if your model was one of the ones they extended the warranty for.
Oct 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Blue Haze on screen Sony cineza vpl-hs50 projector
Its your blue polarizer going bad. This happens over time due to the excessive heat generated in the projector. The main problem is that your projector has organic LCD panels that degrade over time and in turn degrades your blue polarizer. The same thing happened to my sanyo Z2. It took 5 years for it to show on my Sanyo because I only use the projector for sports and movies. not daily tv watching. In any case, it isnt worth it to spend the money ti fix it...jut put tat towrds a new projector. The latest crop of LCD projectors almost all use in-organic LCD panels that last much longer. Hope this helps.
Aug 03, 2009 | Sony VPL-HS51A / VPL-HS60 Multimedia...
Blue haze from lower left slowly starting to consume the screen
The blue LCD panel in the light engine is going bad. The only fix is to replace the light engine. This is an extremely expensive repair. However, Sony has extended the warranty on the light engine only on many of these models. Find a local Sony authorized service center and give them your model and serial number to see if yours qualifies for the warranty.
Jun 04, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Purple-blue haze and line across my Mitsubishi wd62530 screen
hi this fault could be the convergance ic also the resistors and capacitors need to be checked, thanks
shaun
Jun 26, 2017 | Mitsubishi WD62527 62 in. LCD HDTV
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Mar 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Blue haze in lower left corner on screen
if you have any speakers near the screen the magnet may be causing the problem. i had a similar thing happen & when i moved the speaker the problem went away
Jan 02, 2009 | Televison & Video
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
Electro Med Services...
