I cannot access my email account provided by my ISP when hooked up to this router. It accesses just fine when I am connected directly to the modem. I have called Netgear tech and still couldn't get it to work. We turned off the firewall that comes on WGR614v7. HELP!!!
There are numerous ports used and methods to send and recieve e-mail my setup uses the pop / smtp method where I believe the default ports are 110 / 25 however my ISP
uses two other ports. Routers with port filtering enabled may allow 110
and 25 by default but are unlikely to permit other ports chosen by your
or my ISP. The riskier change is to disable all port filtering. The
safer option would be to open the ports required by your ISP (as well
as closing the default ports that are unused).
In order to achieve this we will need to determine the ports you utilize for e-mail.
We will need to be able to access the router for configuration with a web browser.
A second option is that your computer has a firewall
blocking your e-mail ports. However if this were true your e-mail would
never work. The process is similar to the router in that the required
ports would need to be open or the e-mail program given permission to
access the internet in your computer's firewall program.
This
could be a lengthy process determining your e-mail client accessing the
configuration to determine the ports used. Determining if the router
and/or the internal firewall are the issue and making the appropriate
changes to one or both as determined necessary. If you, your neighbor
or a friend is knowledgeable in these areas it may be easier to have
them as
tv says connected to router will not access netflix
