Lisa f-05 code on wd860
    Problem Solver:
  • 17 Answers
F 05 means that your pump is blocked .
If you look at the front of your washer and look at the bottom you will see a kick plate running along the bottom of your washer . take this off by gently pulling it towards you.
You will then see on the right hand side a black round cap. unscrew this but becareful because water will come out so get a tray or a bowl ready. When this cap is unscewed look into the hole and you should see eaither the blokage or a small fan. If there is no blokage try turning the fan with your finger but makesure that the washer is UNPLUGGED. If it rotates freely and thereis no blockage then your pump will need replacing
Posted on Dec 11, 2007
2 Suggested Answers
techbuster
  • 5081 Answers
SOURCE: Wd860 showing error F-05. What does this mean?
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Posted on Apr 22, 2010
My car is a 2004 model. The VSC light is on. The codes are: U0123, U0124, and U0126.
Lisa,Check attached links,instruction and guides they will tell you all about the codes U0123/0124/0126. Read through the links very informative.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://tijil.org/Manuals/xB%20Repair%20Manuals/04%20xB%20Repair%20Manual/05%20-%20Diagnostics/CAN%20communication%20system/DTC%20chart.pdf
VSC and TRAC OFF light on SCION
Check Engine VSC TRAC OFF lights on my xB Scionlife com
https://ca.answers.yahoo.com/question/index?qid=20110130175434AAD5QZi
Apr 09, 2016 | Scion xB Cars & Trucks
May i know the zip code of point lisas, trinidad?
  • Point Lisas,Trinidad Zip Code is 679-7837
Regards, Tony
May 19, 2011 | Audio Players & Recorders
Apr 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
WD860 washer dryer not heating up.
You are definitely right. The heating element needs replacement. So, go ahead.
Nov 02, 2009 | Washing Machines
MY HOTPOINT WD860 WASHING ACHINE HAS FLASHED F 05 DOES ANYONE KNOW THIS PROBLEM CODE.THANKS
F05 indicates that pressure switch is jammed on full.
Remove lower rear panel of washer, and locate and remove large black hose on bottom of drum, remove and clean filter inside of hose.
Please rate my solution.
Thanks.
Aug 30, 2009 | Washing Machines
Hotpint washer will not spin
F 05 IS A PUMPING PROBLEM CHECK IF FILTER IS AT BOTTOM FRONT R H S.CLEAN OUT AFTER EMPTYING.IF NOT AT FRONT IT IS LOCATED AT BACK OF MACHINE IN PANEL AT BOTTOM . THE FILTER IS IN THE BLACK HOSE COMING FROM TUB. ++++ REMOVE PLUG BEFORE DOING ANY OF ABOVE +++++
Mar 23, 2009 | Hotpoint Ultima WF860 Front Load Washer
Flashing f - 05
Error f05 is a problem with the pressure system usually caused by a blockage. These are most commonly found in the pipe which is attached to the bottom of the drum.
Take off the access plate at the back of your machine and you can see it is secured by a large jubilee type clip.
Please be aware that there will be water in this pipe.
Hope this helps & thankyou for using Fixya.
Jan 24, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
F7 fault code on Hotpoint WD860
Fault code F7 is a heater relay fault
Sep 25, 2008 | Washing Machines
Hotpoint Ultima Washer/Dryer Supersilent....
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve.
Feb 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Error codes
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Nov 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
194 people viewed this question
Top Washing Machines Experts
