Question about Hitachi Vacuums
When put on fused all my electrics in house. Now does not work . fuse is ok. wondering what else may have caused this. vax is only 8 months old but lost receipt.
  • 79 Answers
Sounds like motor has blown - fuse in house blew quickly, before the one in the plug had time!
Posted on Sep 09, 2009
Vax stopped mid vacuuming,as though fuse in plug has blown.checked fuse,OK.no lights lit.vax not working.
Most vacuums have thermal protection on the motor that will shut it off if it gets too hot. If you can turn it off, wait 10-15 minutes, and it works when you turn it back on, that's what is going on. Now, the motor shouldn't normally get that hot, so your next challenge is finding out why. Check for any blockages in the air flow or cooling vents, and if the motor also powers something like a beater bar, make certain that it turns relatively freely.
Feb 02, 2016 | Vax Vacuums
My vacuum keeps blowing the fuse. It's about 8 months old and is running good. I looked over it, all wires and plugs are good.
A fuse blows when the current in it exceeds rated capacity. Obviously, it is happening all the time as different fuses keep going south. That means that the motor of your "running good" vacuum is using excessive current.
It is only 8 months old and still under warranty.
Only other thing you can check is the rating of the fuse and the rating of the vacuum. If it is near or same as fuse then that will cause a problem.
Sep 21, 2015 | Vacuums
Vax floor steamer is not steaming
First check the fuse in the power point plug, and replace if necessary. If ok, then it is either a loose or disconnected electrical wire, defective on/off switch, or a burnt out heating element.
Aug 26, 2014 | Vacuums
Why is my VAX 121 blowing my fusebox ?
"Blowing" FusesWhen a fuse blows, replace it with an identical [same Amperage rating] new fuse.
IF the replacement fuse also blows, then that is an indication that there is either a short circuit condition in that circuit, OR you have an overload condition due to too many electricity using devices connected to that circuit, or one that draws too much electrical current [current is measured in Amperes (Amps), or milliamps (thousandths of an Amp)].
The fix" for repeatedly blowing fuses is to troubleshoot the circuit involved, find and identify the fault, properly repair it, and then install another good fuse
Jun 25, 2014 | VAX Appliances Vacuums
Why does my vax rapide not turn on?
The only easy answer would be a bad connection at the plugin receptacle, a bad receptacle, open circuit-breaker or fuse at your electrical panel. Assuming these have all been verified as working
(check by plugging it into a different circuit in the house. If it works then the problem is at the original receptacle and not the vacuum). Then the electrical wiring and components of the vacuum must be checked. This is normally done by a qualified serviceman.
There is no rest button that I am aware of. Make sure the switch is pressed on firmly. The most common problem is a faulty switch, however there are several other possibilities. The vacuum has a simple overload switch that turns off when it is overloaded. Once it has cooled, it will close in again allowing it to work again. This could fail open but it is rare unless it has operated many times previous to not starting now. A more common problem is a broken or open wire. This usually happens at connections and may be burnt open because of a loose connection. Sometimes the start switch on the motor fails or the motor itself fails. Unless you are knowledgeable with working on electrical circuitry the repair should be done by a qualified repairman.
May 15, 2014 | Vacuums
When I switch off my Vax G3 cylinder cleaner it trips out the whole of the ring main circuit - I think the on/off switch is defective and wonder how much it would cost to repair and who - it is just over a...
Hello Lyra_cross, if your machine is in warranty please call the Vax Careline on 0844 4128 455, with your machine and receipt available, and an Advisor will be able to help you arrange a repair/replacement free of charge; if you do not have proof of purchase, Vax can provide a £60.00 repair service which includes collection by courier, inspection and then either repair or replacement and then return to you, again by courier, with a 12 month warranty.
The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team
Mar 13, 2010 | VAX Appliances Vacuums
Vax v-060p not powering up
All houshold electrical appliances which are constantly moved about eventually stop working due to fatigue. The most likely cause of your problem is the power cord from the wall outlet.
Replace the power cord then check again to see if it turns on.
Best wishes,
Graemevm
Jun 06, 2009 | Vacuums
HAVE GOT A VAX TURBOFORCE UPRIGHT HOOVER WHICH WILL NOTB STAY ON AS SOON AS I SWITCH IT ON IT GOES BACK OFF STRAIGHTAWAY, IT IS A VAX TURBOFORCE 1700 VACUUM
i have one of these too and it used to keep cutting out, replaced the filters and now it wont even turn on.  changed fuses everything, and now im stuck with a dirty house....
Apr 16, 2008 | Vacuums
Vacuums Logo
107 people viewed this question
Top Hitachi Vacuums Experts
JoeVacs
Are you a Hitachi Vacuum Expert? Answer questions, earn points and help others
