Question about Canon IPF6100 InkJet Printer
What would cause light 'dots' to appear when printing to canvas using a ipf6100. these dots only appear on some colours
The fabric on my pushchair has torn/frayed, what is the best fabric to use to repair it?
Canvas. Google to find your local canvas supplier. Canvas comes in many grades and colours and is not just used for tents.
Nov 04, 2010 | Baby Gear
Using Epson c86 printer. black Ink dots appear
It may be caused by waste ink at bottom plate of head. Print blank pages about 10.
Nov 12, 2009 | Epson Stylus C86 InkJet Printer
4 colour dots on printout but not 150mm apart
Measure the distance between two of the same coloured dots down the page, if it is just over 150mm then it is caused by scratches on the photoconductor drum (this is the only thing that has a 15.4mm circumference). Try printing a black and white only document, only the black dots should appear. Removing the photoconductor and gently polishing the blue drum with a soft cloth can help if the scratches are not too deep, otherwise a new photoconductor is the only route.
Sep 06, 2009 | Epson Aculaser C1100 Printer
My printer has just stopped mid printing, status light is red and the light under the black dot is red suggesting the black toner is the problem. The print on last page printed didn't appear faded and I...
yhe problem is that you exceed the amount off alow data go to printer options and select print from computer (it will be a lot slower) but you will solve your problem
Jul 28, 2009 | Samsung CLP 300 Laser Printer
We have just changed the photoconductor unit on our Epson Aculaser CX11NF printer. When we print or copy, we get coloured spots on the right hand side of the page
Oh-ho! The coloured spots are what is known as "traffic lights". To be sure these are the symptoms: You will have a black spot then a slightly larger gap then the three colours regularly spaced, the pattern will repeat every 150mm or so. If you print a black only page then only the black dot will appear, print with any colours and all four dots will be printed. It is caused by a tiny/slight scratch on the photoconductor (PCU) drum (usually caused by mishandling, a loose or foreign object inside the printer or even trying to print on stapled paper!). Polishing the drum using a very soft dry cloth can often help to get rid of the scratch, but remember to keep it away from any bright light as this will damage the sensitivity of the drum. The traffic lights will be in line with the scratch so concentrate your efforts in that area. Also, while the PCU is out, take a good look inside the printer for any loose or protruding objects, rotate the toner cartridges from above with the front cover closed (opening the front locks the cartridge carousel in position). I sincerely hope this helps as the only other remedy is to replace the PCU with a new one.
Jul 07, 2009 | Office Equipment & Supplies
11 blue dots print out down the left hand side of documents
It's probably the toner cartridge again. See if you can spot defects at the cyan drum unit that matches the marks on your printout.
Apr 14, 2009 | HP LaserJet 4600dn Color Printer
Solution for "I have a Epson Aculaser c1100 and four coloured dots have appeared when printing. These dots are approximately 5cms from the left side of the page and print in a small vertical group. Each...
The four coloured dots are what is known in the trade as "Traffic Lights". They happen when the photocuductor (PCU) drum gets scratched. If you do a black only print you will only get a black dot, if you do a print with some colour in it you will get all four dots repeated at 150.41mm (PCU drum circumference) intervals. The best answer would be to replace the PCU but it is expensive. The alternative is to take out the PCU, find the scratch and try to polish it out with a very soft cloth. This will only work on the lightest of scratches. Be very careful not to scratch the drum further and avoid shining any bright light on it as it will damage the photo-sensitive surface (normal ambient light is OK).
Apr 11, 2009 | Epson Aculaser C1100 Printer
Epson 10600 colour problem
try to add some color profile in the color management for the printer.You can search the color profile by key word "color profile for photo shop for printing on epson stylus pro 10600"
Mar 01, 2009 | Epson Stylus Pro 10600 InkJet Printer
it sounds like the CYAN toner cartridge is leaking.
Jan 22, 2009 | Office Equipment & Supplies
Canon IPF6100 InkJet Printer Logo
53 people viewed this question
old marine
old marine
