Beep codes bep beep beep codes
    President:
  • 1,447 Answers
You check memory stick i mean extended ram surface clean with eraser or change ram
Posted on Sep 09, 2009
  • Sazeed Computer
    Sazeed Computer Sep 10, 2009
    please change RAM i am sure solve your problem
  • 4,281 Answers
First check your num lock key on key bord if it is turn on and off when you press numlock key then your cpu not need to check but you need to check connection from your monitor to cpu vga port.
When you power up the computer press F8 key then enter in enable vga mode.
Then go to dispaly proeprty in control panel then change screen resolution to 1024*768 then restart.
But your numlock key is constant then you have to open cpu cabinet.
Refix RAM memory.
Remove all pci cards from PCI slot.
Pull cmos cell for 10 minutes so all settings are defaults.
Clean dust from all parts.
Open processor and processor fan then put again to its position.
Some times motherbord grounding with cabinet so open motherbord and check it in out side of cabinet.
Try above this 1 by 1 then check .
If still face issue then your motherbord has some issue.
Also check after change RAM memory.
Let me know if you need more assistanse.
Thanks.
  • 76 Answers
It really depends but here check this out... http://www.computerhope.com/beep.htm
Bep problems of the computer
You mean you can't start your computer and it "beeps"? If is that so, then it means you've received a BIOS beep code which means you have problems with your RAM, video card or the motherboard or its configuration (it depends if it is a laptop or a desktop computer).
You should reseat (take out and put back) all the components and reset the BIOS (remove the CMOS battery, keep it out for a few minutes and replace it). Then try again. If the problem isn't solved just tell and we'll try to understand what is wrong.
Jun 13, 2013 | Computers & Internet
Beep bep bep
Error sound beep beep beep, that's your memory or otherwise you have a device card and it does not inserted correctly.
Mar 15, 2012 | ASUS A7V8X-X Motherboard
When i connect the tv on to the power outlet it beging to do a bep sound (bep bep bep bep bep etc.)
Thats usually caused by the flyback and HOT transistor. You can get the flyback with hot repair kit for your model from www.tvrepairworld.com
Jun 28, 2011 | RCA P46924 46" Rear Projection Television
When i power on my thinkpad t42 the blower fan is working but ther is no display in the screen and ther is one long beep and two short beep. i don't know what happen to my laptop. please help me!...
IBMThinkpad BIOS Beep Codes: Beeps/Error Description Continuous beeping System board failure
Try reseating the RAM module/s and if you still get this bep code then the RAM may be faulty.
Remove the RAM module/s and take it to a computer repair shop and ask them to test the RAM for you.
Jun 23, 2011 | IBM ThinkPad T42 Notebook
Bepping sound,nothing on screen
check your ram stick. take out one by one till beeping stops.
Jan 05, 2011 | Acer Veriton 3600 (V3600GT00150) PC...
We changed the batteries and the lock will not reset it will not lock or unlock just keeps bepping
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing. http://www.weiserlock.com/en/SupportPortal/SuggestedFaqs.aspx?prod=FAQ+Categories_Keyless+Entry_Power+Bolt+1000
Oct 04, 2010 | Weiser Lock Powerbolt 1000 Lock
Hp dv6000 2 beeps when powering on...
Usally when laptop beps when it comes on it could 3 differnt things 1.ram is to much 2.hard drive failed
3.or you have a programming promblem.
Dec 12, 2009 | HP Pavilion dv6000z Notebook
When i turn the laptop on it just beeps several times and the battery and the circle with a Z looking thing light up.
Ok, the tilted-Z-in-a-circle represents the power indicator. As far as I know the power indicator is orange while the battery level is below 60% and charging, and green above 60% and charging. When the batery level is above 90% the power indicator starts blinking (green blinking) to let you know that the battery is almost fully charged.
Please try to turn on the laptop without the battery attached and secondly without the power cable attached. Does the laptop still beeps?
If yes, this could indicate a failure of the battery / charger / mainboard charging bridge.
First, if the battery starts to fail, you should be able to start the laptop by removing the battery. If this helps then you have to buy a replacement one.
Second, check the power the charger outputs (by using a voltmeter) and compare the voltmeter reading with the power adapter specifications (read the sticker on the power adapter). If there is a difference of more than 1-2 volts then it means that the power adapter is toasted. Buy a new one and everything should be ok.
Third - if the mainboard charging bridge has problems - this can only be investigated by a laptop service specialist. It can be fixed either by replacing a passive part or by replacing the motherboard.
The beeps you hear can be a code by which the laptop tries to tell what the problem is.Please describe the beeps and the timeout between them(e.g.: beeeeeep-------------bep---bep---bep -- this is the signal that the VGA adapter is no longer recognized).
Please rate this solution to keep the good answers comming!
Good luck with your tabled PC !
Dec 04, 2009 | IBM ThinkPad T43 Notebook
Gigabyte GA-945P-S3 bep codes
Hi there. How many beeps are there and are they long or short?
Jun 04, 2009 | Gigabyte GA-945P-S3 Motherboard
ASrock beep sounds???NO display
hi cathy
please specify
1.- pc?
2.- os
3.- model
and the properties about this
example... hard disk, ram, proscesor...
i think the problem is any hardware but i need more data
Oct 21, 2008 | Asrock Computers & Internet
Computers & Internet Logo
1,090 people viewed this question
David Payne
David Payne
