Hp photosmart 2710 all-in-one printer will not turn
Hp photosmart 2710 all-in-one printer fax scanner copier will not turn complete on
    President:
  • 1,447 Answers
Must be change cartridge
Posted on Sep 09, 2009
    President:
  • 1,996 Answers
Some of these power issues are caused by having too many devices plugged into a single circuit, or using a surge protector that isn't delivering sufficient amperage to the printer. See here and here.
If that doesn't seem to correct the situation, try a partial reset by following the instructions for that in this article.
If you are getting error messages or have other questions about your model, see you home support page here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
How do I send a fax on the hp 2710?
  1. Click Start , point to All Programs , point to Accessories , and then click Paint .
  2. Click File , and then click From Scanner or Camera .
  3. Make any desired setting changes.
  4. Click Scan .
Apr 06, 2010 | HP Photosmart 2710 All-In-One InkJet...
Running windows 7 with HP 2710 will print but cannot scan
Make sure that..wires are connected properly between printer and computer. Wire cud be faulty. Check if scanner lite is moving on scanner bed. There cud b faulty scanner.
Nov 29, 2009 | HP Photosmart 2710 All-In-One InkJet...
HP 2710 All in One Printer/Scanner/FAX and Vista
There are two models of printers starting with the number indicated. Both have Vista drivers and both have documented vista installation issues. Using the following link
HP Photosmart 2710
Select the correct model
Under software and downloads you will find the software necessary.
Below that you will see a link for Trouble Shooting software ...
Click it then Windows Vista and you will see two potential installation issues you may encounter.
Dec 17, 2007 | HP Photosmart 2710 All-In-One InkJet...
The printer will not scann to the computer
Are you able to print? I suspect so. If not your probably looking at a bad cable or corrupt windows drivers.
The director software uses it's own system to talk to the printer via scan / fax though printing is controlled by windows itself. Since scan and fax are the same function to the printer, essentially i would start by re-installing the director software.
1. Remove it via add/remove programs, don't reinstall over. It may work but you'll likely just waste time, you want all it's files gone and replaced with new ones.
2. If that has no effect remove the printer from Control Panel > Printers. Also remove the scanner device from Control Panel > System > Hardware > Device Manager >
3. Reboot, windows doesn't really remove things till you shut it off.
4. Install the director software again, hook up the printer when asked.
Again:
If you can print at all communciation with the device is perfectly fine from a hardware perspective.
If you can fax without the computer then your scanner and such is fine from a hardwware perspective.
So your problem is simple software, either windows devices install or hp director. Both simple to remove and re-input.
It's very
Nov 09, 2007 | HP Photosmart 2710 All-In-One InkJet...
159 people viewed this question
k24674
jasbo
jasbo
