Gatewy laptop screen
Directions on how to replace a screen on a gateway laptop computer
  • 298 Answers
Replacing a screen is fairly easy, usually you will see some rubber bumpers at each corner of the screen, removed those and that will expose the screws, then you will need to gently pry apard the front bezzel from the back shell. after that you will need to remove any screws holding the LCD in place. Locate the model of the screen and find on on ebay or through your laptop manufacter. I just picked up a 15.4" lcd for a toshiba on ebay for 80$ with a 6 months warrenty.
Posted on Sep 09, 2009
How do I replace keyboard on Gateway EG70
Keyboards are easy to change in most laptops, just be easy when installing the new one... don't press any keys down at an odd angle or the keypads will come off! You will need a precision screw driver set... usually used to service watches and small electronics. Tiger Direct sells them. Nothing fancy, run about $8. The parts manual for your PC or laptop with have the schematic which shows you the parts, study it carefully to determine which screws hold the pieces to remove the bezel that surounds the upper part of the keyboard, just under the screen. There are a few small screws there. The keyboard in then extracted towards the screen and an angle, disconnect the ribbon connector for it as soon as you can get a little access to remove it. It just slides out with a little pressure, don't tug on the ribbon cable or you can break the connector. Put the new one in the reverse order and replace the bezel.
Feb 27, 2015 | Gateway Computers & Internet
No display but ram and processor is okey..
1.Confirm the Gateway notebook is not powered off or in standby mode. Tap the power button to turn on or wake the computer.
2.Check the screen brightness. Hold down the "Fn" key, then tap the up arrow on the directional pad to increase the brightness of your Gateway 400's display.
3.Toggle the notebook display. If you have an external monitor hooked up to the laptop, hold down "Fn." Press "F3" until the display switches to the laptop, or until both the laptop and the external monitor display an active screen.
Sep 22, 2011 | Gateway M360SE Laptop Charger...
I have a lt2030u gateway netbook I need a ribbon cable that goes from the screen into the keyboard. my screen is ok but when i close or open the screen flickers if I put pressure on the left side joint...
Jason,
AMAZON
no hits.
A eBay check for:
lt2030u gateway display ribbon cable
(and)
lt2030u gateway LCD ribbon cable
NO HITS!
Then I tried hunting for:GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREENS and found this part number for the SCREEN: Gateway F846431 hoping to track down a supplier? NO HITS there either!
My final recommendation? Go to eBay and look for Auctions:
352215358996
122852779509
Now go to the bottom and "Ask buyers and sellers about this product"... MESSAGE the guy OR ~ CALL him at:
(201) 830-1637
between 11:00 Am - 6:00 Pm ET
Monday through Friday (excl holidays)
MAYBE they have your cable?
Anthony
GATEWAY LT2016U LT2022U LT2030U LAPTOP LCD REPLACEMENT SCREEN 10 1 WSVGA...
Dec 11, 2017 | Gateway LT2030u Netbook
I am looking for the manual for a Gateway laptop
safemanuals.com/user-guide...owner-manual/.../400VTX-_E
Nov 06, 2009 | Sewing Machines
Can i replace my Gateway laptop tft screen with a new lcd screen?
The screen resolution is a combo of:
  1. the screen's capability
  2. the video card's capability
  3. the driver's settings
If the above screen is made for this laptop (as it appears to be), then the settings you had should still be there.
Jul 29, 2009 | Toshiba LCD TFT Monitor
Gateway M305 power adapter replaced by Gateway. Now blue screen
Try running it just on battery. Then take the battery out and just run if off the adapter. see what happens..and call Gateway and complain..if it doesn't run off the adapter then you really need to call gateway..cause you're stuck without a working computer.
Mar 22, 2009 | Gateway M305CRV Notebook
Laptop screen will not come on
Incompatible screen - replace the screen.
Mar 12, 2009 | Gateway 7330GZ Notebook
I have a Gateway Laptop purchased in 2006.Serial # 0036378223. This computer warranty is expired. It has recentlty gotten dropped and damaged. I would like info on sending it in to Gateway to be fixed.
This is directly from Gateway's websit ein regards to this issue.
How do I send my Gateway product for service and repair?
You must contact a Gateway technician for authorization to send in a Gateway product for all in or out of warranty repairs. Upon exhausting troubleshooting resources, the technician will determine if a product requires service. Contact technical support through e-mail, chat or by calling the correct number as listed below. You may also contact Gateway technical support at the following:
  • Home/Home Office Direct (For products purchased directly from Gateway on or after Jan. 1, 2005): (800) 846-2301
  • Home/Home Office Direct/Professional Direct (For products purchased directly from Gateway before Jan. 1, 2005): (800) 846-2301
  • Gateway Retail (Gateway products purchased from any vendor other than Gateway): (408) 273-0808
Sep 29, 2008 | Gateway Computers & Internet
Computers & Internet Logo
David Payne
David Payne
