Pyle Pro PZR 3000 Watt
I need the exact size of the four fuses inside of this amplifier, i replaced them with 6.3amp fuses and the protection light still stays on, and the fuses blows out, what should i do?
  • Audio Player... Master
  • 5,126 Answers
I think you will find that something has failed and is causing a short circuit, that's the reason the fuses are blowing and not because you are fitting the wrong type.
I should look at the main devices (anything on a heat sink) first. If they are transistors, you can test them with a Ohm meter. If it gives a reading as if the transitors was acting like a piece of wire, it's gone.
Sometimes you might see evidence of burning or even a hole in something.
Posted on Sep 27, 2009
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
PYLE PTA 3000 cut off and will not come on
Will it no longer come on anymore, or does it take multiple tries before it comes on? If it has stopped coming on all together, you may have blown a component on the unit.
Oct 20, 2013 | Pyle Pro Ppa300 3000 Watt 2 Channel Dj...
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
I've purchased a Pyle amplifier... It doesn't work!
your first mistake is buying anything pyle..... check your remote wire that should do the trick
Apr 01, 2010 | Pyle 1800-Watt 2-Channel Bridgeable MOSFET...
What size amplifier to I need to operate a Pyle Driver Pro 15 inch subwoofer? It is hooked to a 200 Watt amp and there is no sound coming from the speaker?
You may want to check ALL the connections and make sure you are connected properly. You SHOULD surely hear a lot of sound even with such a small wattage amp. Blown speaker? Blown amp? Have them tested. Also the REM or remote line on the amp is a overlooked wire.
Feb 22, 2010 | Pyle Car Audio & Video
Why doesnt my 2400 watt amp turn on?
The size of the wire affects the performance of an amp, but the amp should still turn on. 12 volts is 12 volts. So you tested with another amp, on the same wires, and it works fine.The only thing you can really check on the new amp is the fuses in the side. If those are blown, then you should be able to (Unless the amp is fried, and that's why it blew the fuses in the first place) fire it right up. If the fuses arent blown, and you have all your power, and ground, and still nothing.. Well then in that case the amp is just bad, and regardless of the wattage, you just don't fix a Pyle amp.
Aug 08, 2009 | Kenwood KAC-8152D Car Audio Amplifier
How do i hook two dj amps together
Hi
If you have speakers that are rated to handle at least 600wrms, then I would run each amp in bridge mode, with left going to one and right to the other. If you have 2 pairs of speakers, then you may have to invest in some Y splitter cables or adapters to send right and left to each amp running in stereo.
check out the different configurations you can do in the instruction manual here
The details of exactly the connectors/cables you will need to do this are also all in the manual. the only special thing you need if you go the 2 pair of speakers in a Y adapter. Most electronic hobby shops sell these. Happy to answer any questions you have about this.
Cheers
regards
robotek
Nov 04, 2008 | Audio Players & Recorders
Amp fuse
you need to use a 40 amp
Feb 11, 2008 | Car Audio & Video
Reset button
Without owning one , I checked the manual and, sure enough, there's no circuit breaker shown. I mailed tech support. Meantime check where the AC comes in and the fuse holder ( unplugged) and see if you can find anything.
Jan 03, 2008 | Pyle PZR-1000 Amplifier
94 people viewed this question
 Grubhead
Grubhead
