Question about Refrigerators
Norlake 6x6 freezer compressor
I have a 6x6 norlake freezer (walk in ). The door remained open for 6-7 hours by mistake. Now temperature does not go below 15 degrees F. Technician told me to replace compressor.
  • 11 Answers
No probably just frozen up due to door being left open turn unit off and check internal unit have a look on the evaporator (internal unit) see if it has a covering of ice if so leave of utill completly frost free and then restart I bet it will work
Posted on Sep 09, 2009
Norlake freezer 6x6 not freezing enough
Normally freezers are kept at zero. Most health departments will not allow the temp to be higher than plus 10. If you want to store ice cream, you need to be at minus 10 degrees to minus 15 degrees.
let me know if I can be of any further help.
Sep 29, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
I have a 6x6 norlake walk in freezer. The door remained open for 6-7 hours by mistake and now temperature does not go below 15 degrees. The technician told me to replace compressor as slowly temperature...
I've worked on freezers for over 20 years and have never heard of a compressor going bad because the door was left open. think about a second opinion.
Also, has the cooling coil inside the box developed and frost or ice build up? If so, it needs to be completely defrosted. If you defrost it manually, use a hose hooked up to hot water. Kill all power and hose all build up off. Remove the sheet metal housing ends and be sure there is no ice inside there too. I would go in this direction first.
IN order to kill a compressor under this condition, something really strange must have happened as anything is possible in a refrigeration system. Good luck and hope this helps.
Sep 06, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Can i turn a stepin 6X6 freezer to a cooler
sorry friend! you cannot do so, and do not try it also because due to continous running of freezer, the thermostart will not work and your compressor may get damaged......................have a nice day :-)
May 14, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
I would like to know the standard temperature for a freezer
The factory presets your temperatures to the MID / MID setting of 0ºF for the freezer.
Apr 22, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Walk-in norlake freezer
Check the evaporator coil for frost buildup on the back. Check for frost on the suction line, the biggest line returning to the compressor. If frost is evident at these places you have a defrost system problem. These systems have a defrost timer that defrosts the coil at preset times. Check the timer for proper operation by marking the position of the dial and check back to see if it changes. If it does not change position the timer motor is most likely bad. If the dial is not rotating automatically you can manually turn the dial in the direction of the arrow and put it through a defrost cycle.
May 25, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Norlake walk in fridge
Yes if the evaporator drain is blocked or not attached correctly it causes the humidity to remain in the refridgerator. Just opening the door will cause the warm are to enter and cause the symtoms of rain if the water is not taken out the drain properly.Hope this helps JT
Oct 15, 2007 | Nor-Lake Freezer Norlake Refrigeration 6'...
Refrigerators Logo
88 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
