Need help to identify
What does a thermal limit switch look like, or where may i find it, on the Splendide 2100?
  • 15,935 Answers
Directly on the back of the unit.
It looks like a circular disc - held in place by 2 screws.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
I need a wiring diagram for a Splendide Washer-Dryer machine, model WD2000 S. Someone can help ?
Just finished fixing mine. Found a broken wire at one of the high temp limits. Found tech service manual at Splendide,.com/service/TECHMANXC. It's a pdf file that will walk you through any repair.
Nov 03, 2010 | Splendide 2100 Vented Washer-Dryer
Diagnostic code 5
blocked pump prssure switch stuck on empty here is also your manual for yr machine http://www.splendide.com/service/TRAINMANXC_Complete.pdf
hope this helps
Aug 12, 2010 | Splendide 2100 Vented Washer-Dryer
Where can I find parts for the Splendite Washer/Dryer unit model WD2100
westland sales splendide parts ordering and tech support 800 356-0766
Mar 13, 2010 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Sep 19, 2009 | Splendide 2100 Vented Washer-Dryer
Doesn't completely dry clothing
Make sure lint filter is clean and vent pipe and outlet are not clogged.  If the clothes are getting warm then the element is working.
May 30, 2009 | Splendide 2100 Vented Washer-Dryer
Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
Aug 24, 2008 | Splendide 2100 Vented Washer-Dryer
2100 Splendide
The cycle knob rotating means the machine is in self diagnostics mode. You need to count the flashes that the led is giving, they are in 1 second intervals then repeats after a 5 second pause. Mine had 13 flashes and after contacting Splendide they say it was either a broken wire or a bad ETC sensor. With the help of a Ohm meter it turned out to be a broken wire. Mine is a 2100 vented by the way.
Jan 13, 2008 | Splendide 2100 Vented Washer-Dryer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
