Question about Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN All-In-One InkJet Printer
Can't get my pixma 860 to recognize printhead
What is Canon printer Pixma MP560 error U052?
Canon printer class action suit
Canon USA Inc Consumer Class Action and
http://www.federmanlaw.com/Websites/federmanlaw/images/QUESTIONNAIRE.pdf
"...at least 16 different Canon printer models have been identified that display an error message of "U052: Wrong Printhead Error," after limited use. This error indicates that the printer does not recognize the printhead, or that the printhead itself is faulty, but disables all functions of the printer, including scanning and facsimile capabilities, rendering the printer unsuitable for its intended purpose and use."
Jul 03, 2014 | Canon PIXMA MP560 CLR INKJET P/S/C/F FB WL...
Canon pixma mp630 error u052
FYI, Canon inkjet printer class action suit
Mar 29, 2012 | Canon PIXMA Office Equipment & Supplies
Canon pixma mg5220 wrong printhead error u052
Were you aware of the Canon printer class action suit?
May 24, 2011 | Canon Pixma MG5220 InkJet Printer
Error code U052; keeps saying incorrect printhead installed - the printhead has never been changed
Per Canon's website, and this just worked for my mp620:
Turn the printer on.
Open the cover.
Remove the ink cartridges.
Remove the printhead.
Re-install the above (this resets the printhead).
Close the cover.
Printer should initialize and go to home menu screen.
Nov 24, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Mx 850 gives error code 6A00 . We have purchased
6A00 means the purge unit is not cycling properly. If the printhead can come out of the right corner, you check there for paper scraps. If it's stuck on the right with this error you will need a shop to take apart and see if you need a new purge assembly. The part cost is only around $20.00
Feb 22, 2010 | Canon PIXMA MX850 Multifunction Printer
Changed black in tank. Says load cartridge. Did
Double check to make sure that you have seated the ink into the head correctly and that the printhead is locked in correctly. Sounds like the printhead isn't in properly and the printer can't read the inks as it normally does.
Jan 10, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Can the canon pixma 860 print a sheet of paper in duplex mode
Hello !
Your printer prints 2-sided and you can change the orientation of output from portrait to landscape.
Hope this helps.
Oct 04, 2009 | Canon Office Equipment & Supplies
Printer won't recognize ink cartridges. How to align heads????
try to restart your printer by long press atleast 40 sec. at power button..and while the printer is off..wipe the tab circuit of the carrier with a cloth and alcohol and also the tab circuit of the printhead.. unload and load the catridge..on the printer..and ON it again..
if the problem still persist..
try to replace your cartridge maybe the circuit on the cartidge has been damage...that's why the printer don't recognize the printhead's..
thanks for choosing FIXYA..
May 19, 2009 | Canon PIXMA MP460 All-In-One InkJet...
I have a new Canon Pixma printer. Every time I replace an ink cartridge, the printer all of a sudden won't recognize the cartridge. After I clean the nozzles and play with it, it recognizes the new...
I spoke with Canon and they said the PIXMA 620 does not accept refilled cartridges. Occasionally they work without a problem but you should buy a new cartridge each time. I spoke with an authorized Canon repair company and the technician said that the thickness of the ink in the refills is thinner and can ruin the printhead so even if it does recognize the cartridge, refilled cartridges will ruin printhead and are a bad idea. Canon needs to become more ecologically and economically viable if you ask me!
Jun 10, 2008 | Office Equipment & Supplies
Canon PIXMA MX860 OFFICE AIO-2.5IN LCD 19.4X17.1X8.9IN  All-In-One InkJet Printer Logo
61 people viewed this question
old marine
old marine
