Question about Sewing Machines
Tension adjustment I have a Necchi 537L sewing machine and I am having trouble getting the tension on bottom set so it is not loose
  • Sewing Machines Master
  • 1,388 Answers
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
tension adjustment - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 10, 2009
I have a Necchi Omega 6147. How can I adjust the drop-in bobbin to use upholstery thread to sew heavy fabrics or leather?
You would need to adjust the tension screw so the tension is looser than usual. However, remember to mark the setting BEFORE making any adjustments so you will know where to return the original setting.
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Understanding Thread Tension Threads
Feb 10, 2017 | Necchi Sewing Machines
I have a Necchi 537-L and I would like to know the year of it. Any other information that I could get about this sewing machine would be great to thank you for your help in advance
Necchi 537-L Sandi, Machine made in Taiwan, My guess on age would be early 80's. Links below may help, first link one lady states buy her 537L from sears in 1982., other links are instruction and info.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Life With Lou Necchi 537L Sewing Machine
Necchi 536 FB 537 FA Sewing Machine Threading Diagram
http://www.sewingpartsonline.com/necchi-sewing-machine-instruction-manuals.aspx
Apr 03, 2016 | Necchi Sewing Machines
I have a Necchi sewing machine The bobbin thread is way loose. What should I do
Start out with a brand new needle.
Be sure the machine is threaded properly. Also, the presser foot MUST be raised before threading so the thread will seat properly in the tension disk.
The standard setting for the upper tension is the midway point between the high and low number.
If the bobbin thread is still way too loose, you can try adjusting (tightening) the bobbin case tension. If that does not fix the problem, you can probably try purchasing a new bobbin case for your machine as the old one may be broken or worn.
adjust bobbin tension Google Search
Jan 27, 2016 | Necchi Sewing Machines
I need to know how to set my necchi model 537L to sew on Rayon/spandex fabric. I can't seem to get it right. Material won't feed right.
You may need to lower or increase the pressure on the fabric. You will also need a ballpoint needle for best results.
Jun 29, 2015 | Necchi Sewing Machines
Necchi 537l
Sometimes the cotton is too loose on the bobbin; check this first then try putting the bobbin in again making sure you have threaded it in correctly, hope this helps
Jul 31, 2013 | Sewing Machines
I need an instruction manual for the Necchi Model 537L. My 87 year old mother cannot find the manual. Also, could you tell me what that Model is worth? Thank you
You can purchase a copy of the manual for $10 Here. As for valuation, this is a bit more tricky. Most Necchi's (at least the collectibles) are Italian made. The 537L was made in Japan. There isn't a great demand for this machine nor is it considered highly collectible. You'd be hard pressed to sell it for enough to buy a new machine. If you use sewing machine's I'd suggest keeping it. It was a solid machine. Otherwise, check craigslist and see what other working used machines are going for. I've seen the 537L go for $50.
Aug 14, 2010 | Necchi Sewing Machines
Threading a necchi 537l
There are several Necchi models (and loads more) threading guides shown here, it may well be you can find one very similar to help.
Threading Guides
Mar 16, 2010 | Necchi 3101 Mechanical Sewing Machine
How to thread necchi 537L sewing machine
From the reel pin take the thread to the left and over the top thread guide above the takeup lever, make sure the takeup lever is up and and make sure the presser foot is up, take the thread straight down and round the right hand side of the tension unit and back up the left hand side to the takeup lever, thread the takeup lever right to left and take the thread down any guides to the needle, if the bobbin case goes in the front thread the needle front to back, if the bobbin case goes in the side thread the needle left to right.
Jun 09, 2009 | Necchi 3101 Mechanical Sewing Machine
I have a Necchi 537L it was sold as a comercial machine that could do leather. Mine wont do soft paper! Whats up?
This is not a commercial machine and will give you trouble trying to sew upholstery,especially if you use heavy upholstery thread. You will get loops on the bottom.
It will sew only short stitches,No matter how long the stitch length is, because it only feeds the fabric from the bottom and it will stick.
It should sew regular fabric with normal threads with no problems. There is a pressure adjustment on the top of this machine which may be where your problem is located.Look in your book for instructions.Also, make sure the feed dogs are in the highest position. I don't know how long you've had the machine but if it has been awhile,remove the needle plate and clean the lint out from between the feed dog teeth.
sewman7
May 01, 2009 | Necchi 3537 Mechanical Sewing Machine
I need to know how to thread my machine NECCHI Model 537L Necchi 537L I need to see & know how to thread the top thread on this used one I bought, I've ordered a manual, but I need to sew NOW - anyone...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
sewman7
Jan 03, 2009 | Sewing Machines
Sewing Machines Logo
160 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
