Question about Garden
High Wheel trimmer starts but won't run
High Wheel trimmer started but wouldn't continue running.......now won't start at all.
Model 917.773707
Briggs & Stratton engine 128H02 0515-E10506
  • 26 Answers
Check inline fuel filter..blocked with sediment.
Posted on Sep 09, 2009
I have a Ryobi string trimmer model 875R, I can not get it up to speed . Is there a high speed adjustment on the carb.
Yes, you have both high and low settings as well as an idle screw. It sounds like you need to thin the high side out a bit by turning it CW until it starts to speed up. Do this while it's running and the throttle trigger fully depressed.
Sep 12, 2014 | Ryobi Garden
Husqvarna trimmer starts but head doesn't spin, made a high squelling sound but continued to cut, the next time I went to start it the cord pulled quickly then caught started turned briefly then quit while...
Make sure there is not debris stopping the head. Try removing the trimmer head and make sure the shaft turns freely. If it does the problem could be either the engine or clutch.
Jun 25, 2014 | Husqvarna 28cc Gas Line Trimmer
16hp horz vanguard, only starts with pull start,when running the lights won't work......
have a load test done on the battery as it appears to fail when the current draw is high as in starting taking the current needed to run the ignition syatem
Mar 16, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
We have a briggs and stratton mower that has been in storage for 5 years with very few hours on it, it will start but dies shortly after.
needs to have carb cleaned out. most likely the main jet in the carb is plugged. symptoms include only running on choke and dies when choke is turned to run. or if you only have a primer bulb, it will only run for only a few seconds every time it is primed. if you are qualified to work on the carb, dont forget to start with fresh gas and possibly new fuel line and filter. R
Sep 03, 2012 | Poulan Pro 22inch 625 Series Briggs ...
Won't run full throttle
try and clean the screen inside the muffler
Jul 29, 2012 | Mantis 2-Cycle Gas Mini Tiller/Cultivator
I have a 3.5 horsepower B&S push lawn mower. It is easy enough to start, but once started it fluctuates. Runs high and then low almost as if it will cut off and then it runs high again. What can I...
I have a Briggs & Stratton 3.5HP Model 91212 type 1319E1 engine that I'm having trouble keeping running. Once it starts it will run about ten minutes, then die, and then is impossible to get re-started. Is this a carburetor problem, or possibly a coil?
Kent
Aug 31, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
I can get my briggs & stratton push mower to
Your carb needs to by cleaned out. Needs to be taken apart and cleaned with carb cleaner. There is also a gasket that needs to be replaced. It collapsed and not letting gas in the carb.
Jul 07, 2010 | Poulan Pro 22inch 625 Series Briggs ...
Ryboi weed eater is **** - wont start, can't get wheel head off
Try cleaning the carb with carb and choke cleaner. I spray carb cleaner into the opening behind the air filter and then try starting it. It takes awhile to get started. If that don't work remove the carb and spray it down also. When you get it started play with the choke a little. Move it back and forth till it runs smoothly. Mine sometimes will only run of half choke. Mine is a 4 cycle.
good luck
roundo4
Aug 12, 2009 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
205 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
