Install windows XP
I have HP Pavilion dv5-1110ee with Windows Vista but vista is not working even system are not open. I don?t have recovery disk, I have windows XP therefore i want to install Windows XP. When i install XP then problem comes out.. A problem has been detected and windows has been shut down to prevent damage to your computer. If this is the first time you?ve seen this stop error screen restart your computer. If this screen appears again, follow these steps: Check for viruses on your computer. Remove any newly installed hard drives or hard drive controller?s. Check your hard drive to make sure it is properly configured and terminated, Run CHKDSK/F to check for hard drive corruption and then restart your computer. Technical information: stop: oxoooooo7B (oxF78E0524 oxCooooo34 oxoooooooo oxoooooooo) I am also trying disable the native-Sata Setting but ther is no SATA setting. I am very confused what I do please help me.
    Novelist:
  • 148 Answers
Well this really bugs u out installing Windows XP into a non XP system
All u need is a slip streamed driver for it..
Now dont be confused.. THE SETUP HAS DETECTED AN ERROR & WILL SHUT DOWN
This would be shown when u start installin xp..
Look, the hard disk is Sata & the mother board chip is something different..
The drivers called SATA Drivers required for hard disk to be detected while u prepare system to format..
u can install this drivers but u've to feed them in the setup CD itself...
The Process is Called SLIP STREAMING WINDOWS XP
I've done it.. its very simple but complicated.. i'll suggest u to start comupter with an vista installation disk, now after u start go with the setup.. when u r asked to select Drives, u'll see a tab named LOAD DRIVERS
Click it...
This will ask the drivers file (.inf) to be found..
U need Intel chipset
SATA RAID Controller u can follow the link
http://www.tacktech.com/display.cfm?ttid=414
Now select (iastor-sata-drivers.zip ~201KB).
After u download it, save it to ur harddrive.. to a folder i'll say D:\Drivers
Now gettin back to windows setup, when u r asked to load drivers browse to d:\Drivers and select the displayed file
after it loads the driver, simply restart ur system & insert the windows xp disk..
Now it will ask somethin else, just continue with it..
Lets see whether it works or not...or u can follow the steps of how to create a Windows XP Slip Stream..
If it works please rate me up.. Thanks
Posted on Sep 09, 2009
  • 76 Answers
You sure your HD isn't bad? You could try a low-level format and then try to install, I am assuming you don't mind loosing any data already on the disk.
Factory restore hp pavilion dv4000 without disks
Dear Costmer,
Power up the PC while holding the F11 key down hold the key down for 10 seconds, see if recovery manager starts, if it does not, you have 2 choices.
1. Use the product Key on the COA sticker and a XP OEM install disc to reinstall windows.
2. Order a set of recovery discs
amit.mishra.lenovoservice@gmail.com
Feb 12, 2015 | HP Computers & Internet
Can windows XP be install on HP Pavilion dv7-1132nr with Vista OS
Yes, You can dual boot Windows XP and Vista but you'll be having problem finding drivers if you install Windows XP on this computer since Windows XP supported drivers aren't available on Hp download page. HP has only Windows Vista and Windows 7 drivers for this System.
Hope this helps.
Good Luck.
Thanks for using FixYa.
Jun 13, 2011 | Computers & Internet
1) HP Pavilion a6300f went dead only fans spining, replaced mother board with same make model, now ssytem boots but windows don't come up. 2) tried up grade from Vista Home to Vista professional to save...
For the first one, you need to enter BIOS and set the HDD settings. Maybe you can automatic detect it once and then the system knew where to load system from. If it can see the hard disk and reads it but no operating system found, then you may need to check the operating system on your hard disk.
For the second one, I do think it is better to upgrade to a upper level OS such as Windows 7. While you have Vista you will have better deal with Windows 7. If you do have a agreement with Microsoft to have newer OS for free in a certain period, you can get Windows 7 for free. If you don't have that agreement, you can get Upgrade version of windows 7 with a huge discount if you have Vista.
You can actually back up your data to an wim file on vista and restore all the data and settings after the upgrading. But be sure to keep a full backup of your hard disk and everything just in case.
You can enter BIOS and make sure booting from CD first. Then there is a key you need to press very early in the booting process to launch the recovery. There is also a factory default restore you can use. Did you call HP to find out what the key is and how to use factory default restoration? You can always plug the hard disk to other computer to back up the data and then restore to factory default and put the data back.
Apr 23, 2011 | HP Pavilion Desktop a6300f Intel Pentium...
Alright this may sound big but I have a windows vista hp operating system installed on my #1 hard drive. I am getting the blue screen error, and no longer cant fix it, so as in it's done. I bought an...
Make an clean installation of Win 7 and repartition your Hard disk.Use Genuine Windows 7 to avoid blue screen error.AVG 2011 is a very good antivirus.Use Hard disk sanitizer given in Bios settings.Use Tune up utilities 2011or System mechanic latest version.I think your problem will be solved
Dec 23, 2010 | HP Pavilion DV7-1020US Laptop
HP dv6000 turion processor. machine starts and all blue lights appear. dvd briefly lights and then machine turns off and then turns itself back on and repeats the process.
Preforming a system recovery to return the computer to its original condition may be necessary if the operating system is damaged, or the hard drive is corrupted, or the computer is infected by a virus.
___Also look this> HP expanded the battery pack recall on May 19, 2010. Click here to validate your battery. Performing a system recovery removes all software and files saved to the hard drive, reinstalls the original operating system, and then configures the settings for the default programs. Since the merger of Compaq and HP, several different recovery tools and processes Names for these tools include: Recovery Solution, Recovery Manager, F11, Recovery Disc, Driver and Application Recovery Disc, Roxio BackOntrack, Microsoft Backup & Restore. have been provided for recovering notebook PCs to their original operating condition. To help you select the correct recovery process, the table below identifies the different models, the time frame when they were produced and sold, plus the originally configured operating systems. Click on the name of the document in the right column for detailed information. Choose the Correct Recovery Process for Your Notebook Notebook description Recovery procedure information HP and Compaq Notebook PCs and Mini PCs shipped with a Windows 7 operating system. Recover Windows 7 Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Windows 7 instead of an HP solution. Recover Windows 7 Operating System Using Microsoft Windows Backup and Restore Presario, Pavilion, and HP Compaq Business PCs shipped with a Windows Vista operating system. Recover Windows Vista Operating System Using HP Recovery HP and Compaq PCs using the Microsoft recovery feature for Vista instead of an HP solution. Recover Windows Vista Operating System Using Microsoft Windows Backup and Restore HP and Compaq Mini with Windows XP using the HP solution. Recover Windows XP Operating System On Mini Notebook Using HP Recovery HP and Compaq Mini with Windows XP using the Roxio recovery feature instead of the HP solution. Recover Windows XP Operating System Using Roxio BackOn Track HP and Compaq Mini with Mobile Internet Environment (MIE ). Recover Windows MIE Operating System On Mini Notebook Using HP Recovery Presario, Pavilion, and HP Compaq Business PCs manufactured and sold in 2006 or later . Recover Windows XP Operating System Using HP Recovery (2006 or Later)
Presario and Pavilion PCs manufactured from 2001 and 2005 . Recover Windows XP Operating System Using XP Operating System Discs (2001 to 2005)
And
Recover Applications Using Drivers and Applications Recovery Disc (2001 to 2005) Pavilion PCs with Windows Media Center edition of XP manufactured from 2001 to 2005 . Recover Windows XP Media Center Edition Operating System on HP Pavilion PCs Using HP Recovery (2001 to 2005) Compaq Presario PCs supplied with a Compaq Recovery CD and manufactured from 2001 to 2005 . Recover Windows XP Operating System on Compaq Presario PCs Using HP Recovery (2001 to 2005) Omnibook and certain Pavilion PCs manufactured pre-2001 . Recover Windows XP Operating System and Applications on HP Omnibook and Pavilion models Using HP Recovery (Pre 2001)
Nov 13, 2010 | HP Pavilion dv6000z Notebook
How can change my operating system
To change the operating systems say from Windows XP to Windows Vista or Windows 7 you need to purchase Windows upgrade disk or a full version of the Windows installation disk.
You boot up with this Windows installation CD to install the new operating system and follow the screen instructions.
Sep 30, 2010 | HP Pavilion dv6000z PC Notebook
Operating System
Before you could start the installation remove all the external devices connected to the laptop only ac adapter should be connected the restart the system and hit F10 several times till you see a diffrent screen the BIOS and hit F9 to reset to default and then press yes and then press F9 to save and exit and try to run the installation..
Aug 31, 2009 | Computers & Internet
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
I downgrade vista to xp my hp dv6835, dvr-k17b doesnt work
You need to download Windows XP driver from HP website and install on your laptop.
Nov 21, 2008 | Computers & Internet
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
Computers & Internet Logo
214 people viewed this question
David Payne
David Payne
